Although I'm not familiar with this exact model, the symptoms point to a bad temperature sensor. Although the board could be bad, it's more likely the temperature sensor.
I would replace that before I replaced the board. More cost effective also.
Https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
SOURCE: fridge freezer.
I had to look up where you are from. Being the U.K. you mean 16 celsius, right? If the problem began after you removed the boxes, I don't think its a circulation problem. The ice build up on the inside, and the freezer being good but not the fridge, makes me think the defrost isn't working. I can help you check the controls for this, but without a volt/ohm meter you should call someone.
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
SOURCE: I have a Samsung RS21DPSM
hi
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
hope this helps
SOURCE: flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
