Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Chest freezer not staying cold enough
Hello I have a GE 14cuft chest freezer 6 yrs old.Recently it would warm to 20 degrees F even set to the highest setting. I replaced thermostat and it cooled to -10 but within a few days it was back to +20. It seems to keep running drawing 60-70 watts.If I unplug it and wait a few hours before plugging it back in it again gets cold (down below 0 ) but eventually returns to 15-20 degrees.Any help would be appreciated.
Thanx
Bob
Posted by Darkagedad on
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
Anonymous
  • 3 Answers
SOURCE: Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Posted on Nov 21, 2008
Anonymous
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Posted on Jan 28, 2009
Need lowest actual temps achievable by various upright freezers.
no rule of thumb
maybe if you got a different thermostat that has a lower setting than standard
however as upright freezers are very bad freezers compared to chest type freezers the lowest reading will be around the -35 degrees C
Why very bad -- every time you open the door you dump 20 degrees out onto the floor and the temp difference is more pronounced than opening the lid of a chest unit which keeps all of the cold in the unit
remember the colder the setting the more the compressor is working
Jul 08, 2018 | Freezers
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
My Electrolux TC75 Chest Freezer wont even get cold
well one thing to know if the thermostat is working and if the gas is really enough to allow the unit run well.
Feb 27, 2010 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
615 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
