Question about Belkin (54G F5D7230UK4) Wireless Router
Router not connecting?
I have a belkin 54g router.  It use to work fine, but as time went by i would lose signal for no reason. Now i can't get no connection.  I seem to have a working internet but can,t connect to homepage. I am with virgin media.  Please can you help me. Thanks Donna
Posted by donnaphillip on
  • Belkin Master
  • 7,733 Answers
Posted on Oct 06, 2010
I have belkin g wireless that i have to constantly connect
I have experienced the same issue with belkin routers. First, test your laptop with other wireless connections {e.g. Starbucks, McDonalds, etc..} to see if your laptop's wireless adapter is working okay. If so then it sounds like your Belkin Router needs to be reset to the factory defaults and then your personal wireless network settings re-entered.
If that doesn't work it may have to be replaced.
Please provide feedback...
Cant connect belkin 54g router to internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Hi I have a Belkin 54g router which accoring to
i think your internet connection isa problem
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
There is no connection between my Belkin router and Internet. I took my laptop and router to a service rep who stated everything worked fine in his shop. That is was the ISP who needed to be called. The...
Reset the router . CHeck if you can get a wired connection on your computer working . if it is not update the bios and the wired and wireless drivers. try reseating the wireless nic card as well .
1helpful
My laptop is connected to a Belkin Wireless Router which was working fine. All the lights are on except the wireless light and I'm not able to use my laptop. I have contacted my service provider. They told...
There's happens a bit with my router as well...too often actually, normally when I'm downloading... Usually though it's fixed by just rebooting the router. unplug it for about 5 minutes and plug it back in. Like i said, usually that will do it, other times it's that along with a reboot of my computer
My wireless system seems to lose its internet connection periodically. What might cause this if the modem from the dsl or cable source does not seem to be losing that connectivity?
Yu may well need a router firmware upgrade as a few of Belkins router suffered from this - if you need to upgrade firmware and need help repost and email me and ill find the firmware for you
regards
Mark
Computer sees belkin 54g, shows all bars, when
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
Regards!
Belkin 54g Wireless connection problem.
This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
Hope this was some help...
Tim
Belkin (54G F5D7230UK4) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Resolution IT Dubai
Resolution IT Dubai
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
