Question about Sharp Wizard OZ-800
Replace battery in Sharp OZ-8000 pda.
Where do I access the battery on a Sharp OZ-8000 Wizard Organizer? {Separate from the battery on an IC card}.
Posted by dmorgan834 on
Anonymous
Unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
Posted on Jul 18, 2009
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Sharp Wizard OZ-730
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
How do I back up my Sharp OZ 570
i change new Batteries and then not appear anythint on Screen. pls help.
Sep 24, 2009 | Sharp Wizard OZ-730
Forgotton password for Sharp OZ-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Jan 04, 2008 | Sharp Wizard OZ-730
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
Dec 25, 2007 | Sharp Wizard OZ-730
Sharp wizard oz-730
Oct 10, 2007 | Sharp Wizard OZ-730
Sharp Wizard OZ-800 Logo
Top Sharp Computers & Internet Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
