SOURCE: heater core on a 2003 Chevrolet pickup 4 wheel drive crew cab
if you have air conditioning you will need to take it to a garage and recover the r134, you will need to remove the dash to allow you to remove the heater box, it's an ugly job, I've done a dozen or so and can do it in about 6 hours now, the first time it was closer to 11 hrs, good luck
SOURCE: CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
SOURCE: Single CD Player has a CD stuck..the CD will
while pressing eject,slip another disc in the slot 1/4''. wait a couple seconds till you feel it being pushed out by the original cd. do not put the original cd back in till you have cheched for scratches or a warped disc. hope this helps
SOURCE: 2007 Toyota Yaris Stereo Won't Eject CDs
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
