Question about Fuji FinePix S1 Pro Digital Camera
Every time I turn on my camera, the screen doesn't light up, but the flash works. I have no clue if I took a picture or not. Also when I look through the scope I see down In my left hand corner a green box saying "Error".... uhhhgggg what is going on? Can someone help?
Posted by Janessa Thomas on
3 Related Answers
Anonymous
  • 217 Answers
SOURCE: Fuji S5000 will not diplay object on LCD Screen or Eye View
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Posted on Sep 08, 2007
Anonymous
SOURCE: Big Problem
i need to say if it comes of the slim i need some time /
Posted on Jan 11, 2008
Anonymous
SOURCE: Camera turns off when I try to take a picture!
Try a Re-chargeable higher capacity battery, I hope the problem will not occur again
Raj Thapar
Posted on Oct 20, 2008
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
My Canon PowerShot A460 cam is working well until yesterday, the biggest festival here in our place took place. teh flash, the lcd screen, etc is working... but, when i took pictures, the lcd screen turns...
Please try and reset the mode of the image to see if the LCD does not go blank when shown to higher light. Also if there is no issue with the indoor pictures then it is possible that the auto light detection is giving a higher value to reset the image balancing. Shift from Auto to manual mode and try.
Mar 18, 2011 | Canon PowerShot A460 Digital Camera
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Internal Flash not working-Canon Eos 40D
I've had this happen to me too and I've been researching about it. Aparantly it happens because the camera still think the external flash is attached. If you go into the menu and under flash control, try ot enter the settings for built in flash. If this is the problem it will tell you here that the external flash is still attached. From what I have read to far, I'm not sure how to fix it. I would reccomend taking it in somehwere. I dont htink its a hard problem to fix.
Dec 06, 2008 | Canon EOS 40D Digital Camera
After reseting the dsc w50, becouse of e .91.01., flash is not working
hi worked for me , remove battery take apart, discarge the capistor i think 320 volt DO NOT SHORT THE CAP !!!when dead voltage on cap ,turn on reset all camera and try good luck
Aug 31, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Black screen when trying to take pictures
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Apr 02, 2008 | Kodak EasyShare C643 Digital Camera
Incompatible JPEG format
you are most probably looking at the pictures from the camera screen.... if you use a CF card reader and view them on the PC through internet explorer or any other software they will be fine..
You get this error when the files have been changed on the CF card by anything aside from the camera
Nov 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Flash doesn`t work!!
In warranty case however, in order to repair the above mentioned error you should replace the flash circuit board part number:A1166208A.Price for the spare part is 35 Euro (for my account). If you need more info please advice.
Mar 30, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
AF problem
Jangles, I am having the exact same problem. Have you found a fix ?
Aug 13, 2006 | Nikon Coolpix 5600 Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Fuji Camera Expert? Answer questions, earn points and help others
