Question about Honeywell 4B-H703 Central Vacuum Power Unit
Honeywell 703 central vacuum seems very hot after using
Posted by david allyn on
robert
    New Friend:
David
I recently purchased the same unit and had the same issue. I have since received a replacement and realized where the problem was for me. when Honeywell packages the unit for shipment they place all the extra parts including the muffler inside the canister. If the box is inverted in the shipping process than all those items create pressure on the filter/bag that seals the dirt canister from the suction side of the motor. In my case the bag was damaged/torn from the items inside during shipment and I didn't realize it. The motor then sucks a lot of hair, dirt and debris into it's cooling blades causing extra load when it turns. In my case it was extreme enough excess load that it overheated the brushes and covered everything in black soot. So...if it runs hot i suggest you inspect the bag/filter for holes. best of luck ..it worked for me
Posted on Sep 29, 2013
I need an owner's manual for Honeywell Air Purifier HHT-082-TGT and cannot find it on the Honeywell Instruction Manual website
Hello, this is Ava with Think Crucial.
You may find you online instructional manual for your Honeywell model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hht080hht100.html
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 12, 2015 | Honeywell Pet Cleanair Air Purifier...
Honeywell 17000 Air Purifier manual
Please refer to the link below for the Honeywell 17000 online manual:
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/portable_hepa_air_cleaners_17000.html
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Feb 02, 2013 | Honeywell 17000 Air Purifier
How do I access the filter on a honeywell enviracaire 10500 air purifier
You may find your online instructional manual on how you can access the filter cage of your Honeywell model by clicking the link below.
Honeywell enviracaire 10500 Series Owner Manual Page 7
Ava B.
Jan 13, 2013 | Honeywell Enviracaire 10500 Air Purifier
We can't really afford to replace our F100F2002 Honeywell filter. Is there any way to clean it ourselves?
You can vacuum it but its not recommended by the manufacturer. Try going online to find replacement they willl be a lot cheaper than if you called a HVAC company and bought it through them. Vacuuming the filter will buy you some time. If this is helpful please rate me.
May 19, 2011 | Honeywell F100F2002 Air Purifier
Instruction manual for Honeywell air purifier 17352
Please refer to the link below for the Honeywell model series 17000 online manual:
Honeywell 17000S Owner Manual
Ava B.
Jun 25, 2010 | Honeywell 17352 Quiet Care Programmable...
The Honeywell electronic air cleaner constantly "snaps" even though it is clean. I have inspected the wires and fins, clean and spaced properly. Any suggestions?
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
Mar 05, 2010 | Honeywell (F50F1032) Air Purifier
Where can I get the manual for honeywell hfd 130 air purifier?
Please refer to the link below for the Honeywell HFD-130 online manual:
Honeywell HFD 130 Owners Manual
Ava B.
Feb 28, 2010 | Honeywell HFD-130 Air Purifier
Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Sep 23, 2009 | Honeywell (F50F1073) Air Purifier
Can you tell me the difference between the Honeywell Tower Air Purifier HHT-081 and HHT-090? From what I find, they seem identical.
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Jan 29, 2009 | Honeywell HHT-090 Air Purifier
Honeywell 4B-H703 Central Vacuum Power Unit Logo
228 people viewed this question
Top Honeywell Air Purifiers Experts
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
