If you have any problem with your geyser it is better to contact with Geyser Repairs Services in Hyderabad Dialfix there services were good.
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: no water from hot water faucet
thanks for your question, sounds to me like you have a frozen line, I used to live in Northern, MN on a well, and had alot of time un-thawing water lines, yes it is continuous flow, sorry for having to say this but you need to immediately start tracing your hot water lines and see if you have any leaks, bulges, or ice forming on the line, tap the line with a screwdriver to hear the difference in sound when you find the frozen section, here is the tricky part, if its (pecks line, plastic) then you need to call a plumber, if copper, you can use a torch to un thaw the line, but use extream caution when doing this as many people has accidentally started fires, my best advise is to call a plumber, hope that helped, please get back to us and let us know what you find, thanks again, mr.grzz
SOURCE: no hot water
You may need a circulating pump but I can't explain why it was fine before and not now. What I would do is turn the supply off to the water heater along with the power, remove the outlet supply. Open all hot side faucets in the home, using compressed air blow through the pipes if the air comes back at you, then there is a blockage before the hot manifold. If air moves, shut one faucet off at a time to try and determine where the culprit is. I don't know what else to tell you other than that. If air moves through the faucet every time, then you may want to put a circulating pump on. The only other expination is that when they repaired the pipe, some debris or eccess solder is blocking the hot supply. I have seen rocks in units as well. Because of the fix, you may want to take apart each faucet in the house and using a flashlight, look in the hot supply side to see if you can find any debris in those as well. Its not unusual after a repair, to have debris caught in them. Hopefull this helps.
SOURCE: I have water pouring out of a pipe outside that is
That pipe is connected to something called the T&P (temperature and pressure) relief valve. The pipe that connects to the valve should be run to a drain line so that the water goes somewhere other than all over the floor, but often it just ends a couple of feet from the valve. It's possible the valve has opened because the pressure in the tank is over its limit, but more likely it's the valve's fault. If the new heater was supplied without a T&P, the installer may have used the one from your old heater. Over time the spring inside the valve weakens. Then it can't hold the pressure from the new heater properly. A new valve is under $10 at home improvement stores or larger hardware stores. It just screws into the water heater, so it's simple to replace it if you have a pipe wrench. Turn off the water into the heater and remove the old valve. Use Teflon tape or pipe dope on the threads of the new valve (the store will sell that too), tighten it into the heater, then turn the water back on. That should end your leak. If it doesn't and the T&P valve still opens, you'll need to have a plumber check the water pressure in your home.
SOURCE: No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Testimonial: "Thank you very much, Rick! "
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
