Computers & Internet Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KDS 715S monitor is black and will not turn on
I realize that this monitor is 4 years old but was expensive at the time. It goes black or ''to sleep'' and I can not get it back up. Even the green light goes off and refuses to come back on. I know that the computer is running. Any help out there???
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Champion:
  • Expert 214 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Mentor:
Champion:
Answers
214
Questions
0
Helped
48506
Points
362
It might be a signal issue....try checking your 15 pin cable,
How to take my Lenovo monitor model # 9227-AC1 off safe mode
it is not just a monitor there is PC there,
no PC stated, they work as TEAM. ok.
that being said, 14year old monitors.
no not SAFE but power saver mode,
also called SLEEP MODE to save power losses, (Energy Star and GREEN )
the manual covers this. 9227-AC1 (you missed typing fully this)
'Lenovo ThinkVision L171 9227-AC1 17" LCD Monitor.' AC1 is non USA. this is very old monitor and all have this OLD style internal sleep mode. covered in the manual. circa 2005 old. most this old are dead now from dead CCLF back lamp tubes. but the manual shows push menu key on front then in the OSD MENUS WE THEN FIND sleep timer (clock) Inside the monitor,
http://www.manualsdir.com/manuals/165841/lenovo-l171.html if the PC is silent the monitor goes to sleep. if the PC goes to sleep wiggle the mouse or hit space bar until PC wakes up. if sleep is bad in PC turn sleep off. if PC is dead, then that is wrong. test the monitor in 2nd PC if monitor works there the monitor is ok, and PC1 is bad.
3answers
While I was on my computer today, it suddenly had a black screen with a message that the monitor was going to sleep. I tried rebooting but nothing seemed to work. I connected my monitor to another computer...
Hello, Kpruetz is almost impossible to find the issue without testing and measure your device because of that problem beginning in the computer, not in the monitor; like firmware, filters or other components, I sorry about that. If you have guaranty range you can contact the customer services, then they can solve the issue https://support.lenovo.com/us/en/?menu-id=Technical_Support
My hp w2338h monitor randomly goes to sleep only when I play games. I have turned set hybernation to never in power options, updated all drivers and this still happens I have also plugged in another...
ok , we've answer that question here , vast endless times.
all old monitors before magic year 2010 even go to sleep
all by them selves to save the pathetic, CCFL tubes insid it.
so learn to use the monitors OSD screen.
push the menu button there(real button)
see that? now turn off sleep.
i will now read the manual to you.
3 seconds latter (manualsdir.com)
page 33
turn off the time and all sleep function INSIDE the monitor
amazing no? RTM still works in the year 2018...
https://www.manualslib.com/download/71500/Hp-W2338h.html
EVERY TIME I TURN MY MONITOR ON IT SAYS "GOING TO SLEEP" AND THEN THEN SCREEN GOES BLACK! BUT MY COMPUTER IS STILL RUNING. I THOUGHT IF I COULD GET A MANUAL I COULD TROUBLE SHOOT IT AND FIX IT. BUT WHEN...
its a very very old monitor,so old in fact , you PC then had no sleep modes. so its inside the monitor, this old
so push the menu key on front of monitor and turn off
sleep/powersaver. ,
no the manual is only, you do know fixya is not HP right?
nor are we COMPAQ
did you leave off works in front if the 1501, HP made types with just that 4 digits.
Compaq 1501
https://www.manualslib.com/manual/30085/Compaq-Tft-1501.html
L1501 and TFT-1501
read the service tag on the monitor and see the real full name
then post that for 10x better answers even the book.
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
My monitor stays on for 6 seconds
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is...
if you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Grand Canyon Tech
Grand Canyon Tech
