Posted on Apr 11, 2009
Only 2 speakers working
I have 5.1 speakers and surround sound card.I installed everything,icon of sound card is working,only digital output is not working and I can not get sound from all the speakers.When I tested all the speakers work.I play a song and it is coming out from two front speakers.thank you.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
6183
Points
13
On your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
3answers
Audiophile 2496 no sound
try either right click the speaker icon on the bottom right hand corner of the screen "open volume mixer" click :devices" and select the card you installed. if that fails, go to device manager and disable any other cards the the computer has so it wont conflict. if that fails take it into geeksquad at best buy to see what is going on.
I plugged my speakers into the orange circle behind my computer, and no sound is coming out. Why isn't working?
Hello Shantilla hi, the orange port is for the Center speaker for a 5.1 surround set up. to enable this you need to find the controls of the sound setup. usually on the lower right side of the computer. If the sound card is a Realtek brand the sound manager is the orange speaker ICON, need to open this sound manager software and enable 5.1 surround. You need the SOUND driver to use the surround setup.
2answers
At a time only two speaker works out of 4
1. Open Control Panel > Sounds and Audio Devices. 2. Click 'Advanced' Button near the bottom. 9d7466a.jpg
3. Select proper sound system (Quadrophonic or surround sound) according to your speaker system.fc6ac4d.jpg 4. Click 'OK'. 5. Also check volume. 6. Double-click Volume icon in taskbar. 7. Click Options > Properties (From menu) and select 'Playback'. 8. Select all Audio components. 9. Click 'OK' 10. Increase all the volumes.
Now try playing a sound. Good Luck!
1helpful
When playing dolby digital 5.1 surround dvds it.is not getting decoded.i get the sound in all the speakers.
go to your control panel
click the sound icon
under the playback tab select the audio device you want to configure
right click properties
check each tab make sure you have dts / dd ticked
you may have software from creative installed check this to make sure you have the soundcard setup to output 5.1 when available
make sure the sound is configured on power dvd
if you cant get it working that way i suggest trying windows media player 11
also remember the soundcard will only output 5.1 if the source is 5.1 a copied dvd for example could be 2 channel stereo
i hope this helps you out !
No sound out of the speaker of my lap to dv9000
hi im josh may i he lp you? try this; Sound cards range from simple built-in features to elaborate two-piece devices with physical control panels that mount into a 5 1/4-inch drive bay. The basic purpose of sound cards is to allow the user to hear sounds played by the OS and programs, along with music from audio CDs and other audio files, plus sound from DVD and other types of videos. In addition, these allow for voice communication using software such as Yahoo Messenger, AOL Instant Messenger, and Windows Messenger, along with Internet telephone calls, voice-recognition software, and other uses.
Sound Card Removal and Installation Sound cards are physically installed and removed in the same way as any other card using the same interface (PCI or ISA), except that there are likely to be analog audio cables connected to it inside the computer. On a motherboard with onboard sound, there will also be audio connectors. These connectors are for connecting analog audio to optical drives, modems, and other devices. Some of these connectors are polarized, but even if they aren't, the worst that can happen is that the right and left audio channels could be reversed. Figure 8.4 shows the audio connectors on a sound card.
Figure 8.4: A sound card's audio connectors. External Sound Connections Sound cards can vary as to the number and type of external inputs and outputs. The most basic, usually found on motherboards with built-in sound, have three:
Microphone input: This is for a computer microphone, although battery- powered condenser mics usually work in these jacks.
Line input: This is for an external line source such as a cassette deck or CD player's line outputs.
Speaker/headphone output: This is a headphone-level output that can sometimes drive small, non-amplified speakers. They are usually connected to amplified speakers.
A sound card with a built-in amplifier would have full-power speaker outputs, able to drive most non-amplified speakers. More advanced cards have a whole assortment of inputs and outputs. On many cards, the icons that identify each jack are very difficult to see and interpret, especially when you are struggling just to see any part of the back of the computer. Consult the manufacturer's documentation. Figure 8.5 shows sound card jack panels.
Figure 8.5: A sound card jack panels. Now look carefully at Figure 8.5. The concentric arcs represent sound waves. An arrow pointing toward the center indicates a line input, while an arrow pointing away from the center represents a line output. The microphone and speaker icons are more illustrative than are the others.
Diagnosing and Repairing Sound Problems There are a number of steps you can take to correct sound problems. First, make sure the speakers are powered, turned on, and turned up. Make sure all external connections are correct, and that the cables aren't damaged. Run System File Checker (see Chapter 11). Reinstall the sound drivers. Sometimes, you'll have to remove the device in Device Manager, shut down the computer, remove the card, restart the computer and uninstall any programs that came with the sound card, and then shut down the computer again. Then, follow the manufacturer's directions for installing the card, or just reboot and see if Windows will install it correctly. If you have any trouble with resource conflicts, which would be evidenced by instant lockups, go into the BIOS and make sure Plug and Play is enabled.
Selecting a Sound Card A basic sound card is good for most people. High-end models are good for gamers and musicians. Some people like to have surround sound with their computers, so surround sound models are common.
good luck
2answers
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Sound from 4 speakers cut off..
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
1helpful
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
1helpful
Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
 Grubhead
Grubhead
SmartAviator
SmartAviator
