All the lock's ,were locking an unlocking or just the driver door lock ? Probably wasn't the switch ,more likely a bad input to the BCM . The door lock's are computer controlled .
Do you know what a BCM is ? body control module .
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
SOURCE: Ignition and Transmisssion Locked on 2000 Chevy Malibu
I had a similar problem on a 2001 GM product. The problems all stemmed from a worn out key. Keys are made from softer metals so that they wear out before the expensive cylinder does. Debris had collected in the cylinder preventing ANY key from turning it - corrected that with compressed air. Replaced the key at the dealer by providing the VIN and my ID w/registration - $10.00. Kept the old keys because they still worked for opening the trunk. Try it, I bet your symptoms and fix actions are very similar, at least, I hope so. Regards.
SOURCE: 2008 chevrolet malibu door lock problem
You have a intermittent condition. To isolate the cause: 1.Disconnect the drivers door lock/unlock switch from the connector. Drive the vehicle and see if your random lock/unlock condition has stopped. If it has, replace the switch. If it hasn't:
2. You have a grounding problem or a problem in the BCM (Body Control Module) and should have a technician use a Tech 2 Diagnostic Link Tool to access the BCM computer to obtain any fault code data to help correct the condition.
SOURCE: 2008 chevy malibu. how to program keyless entry remote
You must take it to the Chevy dealer.
Testimonial: "thank you"
SOURCE: 2000 chevy malibu radio unlock help??
are u the original owner of the car ?if so do you still have the books that came with the car? look for the delco radio book !there should be a card in there with a code and instructions! if not the only wasy is to go to the dealer or a radio repair shop to have it unlocked!
SOURCE: I locked my keys in
A lot of today's cars have seat backs that fold down to allow access to the trunk. I guess you would of already tried that. Just a thought. The only other thing I can think of, besides calling a locksmith, is to see if there is a blown fuse for the remote opener.
