LG WM2042 Front Load Washer Logo
Question about LG WM2042 Front Load Washer
LG washing machine keeps stopping and it says OE
The LG front load washing machine stops half way through the cycle and then says OE in the information window. What does OE mean.
Posted by gmvincent on
  • gmvincent Apr 12, 2009
    thank you for the response. Now the drum will not spin and I get an LE message.
Anonymous
    President:
  • 373 Answers
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
  • Anonymous Apr 12, 2009
    LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
robert
  • LG Master
  • 2,548 Answers
Very often this is because the pump(drain pump-not circulation pump) has failed. very common. pretty easy fix. part about $30. go to appliancepartspros.com or repairclinic.com for videos to show how and to get parts(or eBay for parts)
Posted on May 07, 2016
Keikyu
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
1E - Water Supply Failure. Is it connected, water leaked, etc.?
0E - Drainage Failure. Is it clogged, freezed or pinched?
UE - No Spin. Is there any unbalanced load?
DE - Door/Lid Open. Is the door closed?
TE - Unknown Error. Call LG.
FE - The water overfills due to faulty valve. Call LG.
PE - Water level sensor error. Call LG.
LE - Overload on motor. Reduce load size.
CE - Overload on motor. Reduce load size.
PF - The washer expirienced a power failure. Restart the cycle.
TCL - Tub Clean Alarm. Remove all the tub before commencing.
LE1 - Foreign Objects. Some models only.
LE2 - The water overfills due to faulty valve. (replaced by FE)
TE1 - No Spin. (replaced by UE)
BA - The washer expirienced a power failure. (replaced by PF)
Posted on May 05, 2016
Whenever it gets to almost the end of the cycle and usually while it is in rinse, the error message OE comes up and it won't drain the water from the tub or go any further
Had same problem last night with my LG WM1814CW but mine didnt get to the end of the cycle, it would fill and start humming when it was supposed to be draining then the OE would appear. We drained the machine through the front door hose, turned the machine on its side and removed the drain pump. Very easy access and very easy to remove the drain pump. There was a half a bobby pin against the impeller and that stopped the turning. Took the bobby pin out and put it all back together. It works like a charm now. Very nice system that LG has.
My LG washer keeps stopping during spin with the display OE.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
1helpful
My machine just stopped during the cycle, and displayed 'OE'. What does this mean? Why did it do it?
The OE is an overload error. Try removing some clothes. If that does not work you could try unplugging the machine. I have a manual you might want to look through. LG washer manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
3answers
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
1helpful
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
The washer does not go into the spin cycle
if it gives you an oe code then your filter is blocked or bad water pump clean out filter at front of washer (bottom left corner)
5helpful
2answers
OE what does this stand for
oe stands for outlet error possible solutions are : drain hose kinked , filter blocked or the pump impellor is blocked.
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Top LG Washing Machines Experts
Marvin
Marvin
W.L.
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
