Question about Epson Stylus C86 InkJet Printer
My pictures are printing in a red tone on my Epson xp-400 printer. I have tried both cleaning the heads and realignment.
Posted by tim kennedy on
5 Related Answers
issy2
Mohamed Ismail
  • 462 Answers
SOURCE: Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Posted on Sep 09, 2008
Sanath Kumar V
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
Alun Cox
  • 2679 Answers
SOURCE: printer will not print in black ink. Epson stylus color 400
Try cleaning the print heads.
Posted on Jun 19, 2009
Anonymous
SOURCE: Cleaning the heads on a Epson Photo R300
the heads are removable if you remove the back plastic cartridge holder first with pointed pliers then there are two screws at base accessable with printer intackted. you only have to set the carrage to cartridge change position to do this. once removed use a rubber tube on a cyringe filled with water and blow jets through several times and replace as removed....
Posted on Jun 21, 2009
Anonymous
  • 73 Answers
SOURCE: how can i clean the print heads on the epson NX
Might want to check procedure on page 31 of the user's manual.
http://www.retrevo.com/r/23134dj887/31/Cleaning+the+Print+Head#q=Epson+NX400
You can download the page or the entire manual (.pdf).
Posted on Jul 24, 2009
Epson xp-100 realignment, what does this mean? Trying to stop my printer from shadow printing...
The print heads are usually a little out of position on the carriage. All printers have some process to cope with this, called alignment. It prints a few trials and you nominate which is best. It then remembers the correction needed. On your printer it is described here
http://support2.epson.net/manuals/english/spc/xp_200/guide/html/maint_3.htm
Aug 31, 2014 | Office Equipment & Supplies
Epson Stylus SX445W printing pictures with a red tint
Dear Kate,
please run the Epson maintenance software and check your printer cartridge.
i think printer head cleaning is the solution.
please run 1 or 2 cleaning cycles and give a try again.
if problem still there its time to go to technician.
regards,
nuwan.
Jan 10, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
I have replaced the cartridge cleaned the nozzle heads but my photos are a funny fuzzy colour. It is about 18mts old and hasn't been used much Thanks
It's a EPSON printer, you have to use it at least twice a month, otherwise the ink on the print heads will dry and clog them. If the printer cleaning process doesn't solve the issue, you'll have to take it to the service center to get the print heads replaced.
Jan 12, 2010 | Epson PictureMate 500 InkJet Photo Printer
RED WON'T PRINT
Hi-
Try running a head cleaning from your computer, if you are using XP go to printers and faxes under control panel and right click on your printer icon then go to printing preferences then go to maintenance and run head cleaning cycles for 3x then print a nozzle again. if all fails cal epson and check for the warranty so that you can have it replace, coz chances are the nozzle for magenta is clog.
Hope this helps
Sep 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
All pictures printed are blue
Do head cleaning. If your using Windows XP: click on start;control panel;printers and faxes; right click on the stylus photo 1290 icon and then left click on printing preferences.
Go to maintenance tab.Try to do 3 head cleanings. After head cleaning, try to print.If the picture is still bluish; go to printers and faxes; go to printing preferences; click on advanced button.
On the upper right part of the window you should see there color management, click on ICM and turn off, click on apply and ok.
try to print, if it is still the same, try to use another program to print your pictures.
Feb 04, 2008 | Epson Stylus Photo 1290 InkJet Printer
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson CX3200 is Clunking and misaligned
You need to start by cleaning the head from the underside. This rescue kit has a good cleaning guide as well as loads of other useful info and functions.
Dec 04, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus C86 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
