Hi. i was register my garmin 530 but it says in the website''no free space'' so i bought an SD card. when i inserted my device, it still says that ''no free space at G:/Garmin'' so i put the files at G:/ at move it to H:/ (sd card) [meaning files at G:/ was deleted] when i tried to register again, the computer can not read G:/ but when i inserted the SD card alone, the computer can read it. when i open my Garmin c530, it already says ''No detailed maps found that supporting routing. The Streetpilot cannot be used withou them.'' so i figured out that i deleted the device's internal memory. the question is how do i restore them??? i tried everything but still it doesnt work. help me please. thank you
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
SOURCE: reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question:
What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer:
Please follow these steps to troubleshoot the error message:
Checking the unit:
SOURCE: Maps are missing
Same here..the phone support sucks.. i am on hold right now for 20 mins and i am not sure if they have an answer!!
MY GARMIN NUVI 200W NOT WRONG AND SAY NODETAILED MAPS FOUND THAT SUPPORT ROUTING. THE NUVI CANNT BE USED WITHOUT THEM
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Please dont forget to vote this answer was helpful
Many thanks
