2002 Chevrolet Corvette Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio CD player won't play homemade MP3 or WAV CD's.
Attempted to make CD both in MP3 and WAV formats to play on my
2002 Corvette radio CD player. It Err's and ejects the CD.
However it does play store bought CD's. Could it be a format problem
and if so what format should I be using for homemade CD's to
play on it....Thanks much.
Don
  • janicemabry1 Apr 11, 2009
    Nope, copyright is not the problem.. I am making an audio
    cd on my computer which I can play on my other two autos,
    Tahoe and DTS Caddy. It also plays on my other audio
    devices. Does not play on my vette. What format does
    the radio cd player accept?
  • janicemabry1 Apr 12, 2009
    What....!!! got the T-shirt, Buy a Belson in spain.....?
    Geeezzzzzz.
Colin Stickland
Level 3:
  • Chevrolet Master 22,516 Answers
  • Posted on Apr 11, 2009
Colin Stickland
Chevrolet Master
Level 3:
Answers
22516
Questions
Helped
6997575
Points
66324
Your cd is copyrighted with a code it looks for the code on the cd
  • Colin Stickland
    Colin Stickland Apr 11, 2009
    sorry its the cd player ,had this before ---got the T shirt .Buy yourself a belson with the sd card reader and usb ,then you dont need cds just a 1gb sd card or usb stick .anything over 1gb might be a problem.This player is here in spain for around 80€ and its brilliant ,40watt output and plays anything.honest had this with sony and philips ,evan original factory fitted cds.They will only play a bought cd with the country code and music protection copyright.
  • Colin Stickland
    Colin Stickland Apr 12, 2009
    bought in spain made in china or korea ???but it works very well
What type of AudioFormat should I burn some music to and be able to listen in the 2002 Pontiac Grand Prix CD player?
You can try wms or wav. I believe those formats should wok on oldet cd players. Hope it works. Good luck!
1helpful
2answers
Can the radio on a Golf 5 be set to play MP3 CD's?
If the radio was not originally built to play MP3 format, then no. Unless the manufacturer has an update for the player's software/firmware (which I doubt they bother with) it will be impossible.
Cd player error
a stock day 1 03 honda headend radio and CD Player?
yes/no.? if not , post maker ,model number of unit, can look them all up. and even fix them.
try a new , real CD, from a store, called CDDA ,
like Hank Williams.
Does it play now. (yes, progress)
you never said what CD you have, there are vast types.
CDDA (all play)
CD-r few to none.
DVD none.
CR-RW, none.
mp3 , non
your CD came new with a book listing all valid formats
i bet you lost that,
the orig manuals said ., some CD-r play
and only burns (rips) from CDDA, to CDR.
never MP3 or DVD or with complex file structures
hell even new cars , fail with insane complex directory or file structures. (cept my home theatre, amp plays it all. but says it will and does, but back in dark ages of CD NO, not at aLL.)
some start to work and freeze half way but CDDA works always.
if not? the Drive is DOA> the parts are more that a new radio.
I have personally burnt every form, and complexity CD and DVD
and have tried i on many cars. (other home equipment)
today, I DONT, run USB flash , mp3 or wav.s.
CD/s are now relic tech, to me. life is too short of scratches and hang\'s, for me.
answer 2: real new hank disc , any real CDDA .
it gives and error.
that means, :
1: the driver is filthy head lens.
2: motor dont spin
3: optical sensor bad or piece of junk in the gap.
4: DISC LABLE FLOATING ABOUT.
5: MOTOR RPM TOO LOW, AND GOES err.
6: head motor stalled.
can do 20 more , but why , its dead and once cleaned still dead
the parts are too expensive and labor 10x that. why worry dead.
replace it. and upgrade (zero CD)
13helpful
2002 gmc envoy bose 6cd player does not play, shows player error
how to remove a bose cd/radio from dash of a GMC envoy slt cd's are stuck inside
2002 Ram Radio problem
It sounds like a cold soldered joint internally in the radio. My advice is to buy a nice aftermarket radio with an MP3 CD player. MP3 gives you the option to burn music from your computer. In addition, MP3 CDs will hold over 100 songs per CD.
It MIGHT be a poor connection at the power connector on the rear of the radio. You could try pulling out the radio and cleaning the connection before purchasing a new radio.
Delco stereo wont play cd-r (mp3)
I believe CDA extensions are actually just shortcuts to the audio file and not the actual audio file. You will want to convert your MP3's to .wav in order to play them in your radio. Roxio and Nero version 4 and higher will automatically do this for you and a version should have come with your computer or CD burner. Just place the MP3's in the record section and select output audio CD.
1helpful
Can I install a a 2007 Camry CD/Radio unit in my 2002 Camry?
The 2002 and the 2007 radio connections are markedly different. Remember that the 2007's are "satellite ready"; this changes the back side wiring configurations dramitically.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
