Computer will not start windows and will not reboot to operating
This f12dt twinhead slimnote will not reboot in any function
It goes top 86% when trying to restore the windows system
I had an expert look at it and he said the hard drive is corrupt.
can you send me instructions on how to take it appart and replace the hard drive, and do you have a windows xp disk to reinstall on new hard drive.
the serial # is sy6161003375
I believe purchased in 2006 or early 2007
also can you tell me where to get a hard drive from
you need to reinstall your operating system again...no other go...try installing with the help of the operating system CD provided along with the computer...
Have you tried booting in safe mode pressing F8 when starting up just after you power up, then a menu appears & you can try sytem restore from there or safe mode if you know what to get rid of on the system.
If not boot with a copy of windows in the drive & start again from fresh!
Hope this help's !
I believe this model of laptop was designed for Windows 95, which can be installed using only floppy disks. That would be just about your only solution. I would not recommend trying to install XP or anything on it, due to the outdated hardware. If it has a PCMCIA Slot on it (most do) you can buy a USB adapter that goes in there. But, as I stated before, I would just install Windows 95 on it (or possibly 98SE) Good Luck!
sounds like a problem i had with a philips laptop (which appears to be a twinhead repackaged as a philips)
This might sound weird but it works........
Take the battery out and disconnect from the ac
Press and hold the power button for about 40secs
connect the ac but don't replace the battery and press the power button
then replace the battery and turn it on. it should work
