For some reason the sound that should be coming out the front speakers is coming out my rear (surround) speakers. I have a 5.1 setup. When I do the "test tone", I am hearing a tone from the wrong speakers as shown on the front of the receiver (FL shown on receiver but sound is coming from rear left speaker). My speaker connections are correct--I am using "speaker A" setting. I use an optical cable from my HD digital TV cable box to the receiver. Any ideas? I did have a power interuption a couple of weeks ago and that is when the trouble started. I can get sound out of the speakers, but, it is reversed.
SOURCE: no sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
SOURCE: No sound out of Front Left/Right Speakers on 5:1 setup
i have the same problem with my sony receiver. seems like the fronts and sub have no output after sitting idle for about one and a half years. center and rears are ok. any help folks?
SOURCE: connecting media center to receiver
Hey there,
Okay let me start with your pc setup. What type of sound card are you using? Are you using onboard? You have to check and see if the sound card or device you are using supports SPDIF passthrough. Basically this does just what it says...passes the surround sound signal through your hardware with no onboard decoding and uses the decoder found on your stereo. I use a soundblaster Audigy and i had to enable passthrough in the audio console. I also had to enable spdif as my default audio playback device. This is in Windows Vista. You also need to go into properties and set the formats your receiver supports. Once that is complete you need to adjust the audio settings in media center and select toslink as your audio output and select 5.1 audio.
Things should work now...BUT...you will only get surround sound audio when watching a source that has dolby 5.1 or DTS. You will not get surround sound in games =( When i watch ota hd shows that have dolby audio, the blue light kicks on in my receiver and i get 5.1 audio. Same goes for watching DVD's. I hope this helps you out
