SOURCE: Lens Cover Error- Nikon CoolPix S6.
I have a similar problem but it only appears when the battery is discharged. Goes away when I charge the camera fully. I'm wondering if the battery needs to be replaced.
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
SOURCE: nikon coolpix S3- most of the screen is black on shooting mode
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
SOURCE: nikon coolpix S6 screen black
All you have to do is lay your camera with the LCD side down, make sure its on a soft surface like a carpet or a pillow. Once you have it laying down, put a peice or two of newspaper, or any paper, on top of the camera. and then hit it a few times with something. like a brush or anything hard like that. it worked for me. :) good luck.
SOURCE: coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuff It will be helpfull for you. Its is a step by step solution with images.
Regards
Mukesh
