Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
MINI MAGIC CHEF REFRIGERATOR WON'T COOL - Magic Chef MCBR360S Stainless Steel Compact Refrigerator
5 Related Answers
Ronnie Houston
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Posted on Apr 27, 2009
Anonymous
  • 82 Answers
SOURCE: MY magic chef CTB1922 IS NOT COOLING
Sounds like your compressor overload tripping. Compressor may be stuck from sitting. Start relay may be stuck from sitting. Try a new start relay after making sure all your wires and connections are good. Sometimes a wrap with a deadblow hammer on the side of the compressor can get it going. Don't pound on it just a light wrap. My guess is the relay or overload first. Unplug before fooling with any wiring!
Posted on Jun 28, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: why does my magic chef refrigerator leak water on
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Posted on Jun 30, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Where is the defrost timer on a magic chef
The defrost timer for your model is located in the fresh food compartment. Providing the model number above your post is correct. The part number for your defrost timer is 61005388
You can visit my sites if you like and enter part or model number to get the models or parts you need. If you need help or need answers let me know.
Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Jul 09, 2009
The Magic Chef Refrigerator Electronic Thermostat - SF-WB-4/CM will only cool to 45 degrees, Is it possible to change out the thermostat with another factory unit fom a standard mini frig ?
Putting another thermostat would not help it be cooler it actually stop it from functioning all together if it's not recommended by the manufacturer
May 08, 2014 | Magic Chef Refrigerator Electronic...
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
I have Magic Chef refrigerator model MCBR415S frezzer is working but the refrigerator only cools to 52 degress what can be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
Water collecting on shelf above veggie drawer in Magic Chef refrigerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Magic Chef CTF2125 Top Freezer...
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
77 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
