Question about Motorola Mobility V600
Motorola phone screen flashes, need battery ML414, where can I get it
My phone will not go pass the motorola symbol when being turned on and the only way to turn it off or to get rid of that screen is to remove the battery. I have taken out the battery for a matter of mins...
start your phone in flash mode,you do this by holding down the # and the * key while powering up your phone,,you will see a black screen with a bootloader message,,plug the phone into your pc and open motorola phone tools then do the phone updates..that should help...
youll need motorola phonme tools and a computer and a usb cable.. you can get motorola phonje toiols from www.modmymoto.com
Jun 19, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Phone is stuck on weird motorola flash mode screen
I can help you with your Motorola Moto Q flash mode screen problem.
What has happened is that the firmware / system software of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence.
This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware.
The good news is that if you take your phone into your carrier's store, they can reflash the firmware for you right there (if they have a competent tech handy.)
If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times.
My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone.
I hope that helps.
_________________________________________________
Motorola MotoQ Manual Download
Motorola MotoQ Update Manual Download
Motorola MotoQ Verizon Firmware Update Download
Jun 14, 2010 | Motorola Mobility Moto Q
Screen is blue motorola logo says bootloader usb init when try to shut off black screen says verizon tried taken battery out same problem. Thanks
Your phone is starting in flash mode..You need to have either p2k phone tools or motorola phone tools..you can get them from www.modmymoto.com. once you have the software on your PC connect your usb cable and reload your phone
May 11, 2010 | Motorola Mobility VU204 Cell Phone
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
Blank screen, flashing keyboard, confusion
My Motorola Razor cellphone all of a sudden went blank, i took out the battery and put it back in and turned it on, but the keyboard just flashes and the screen stays blank, what do i do?
Jul 27, 2009 | Motorola Mobility RAZR V3
Frozen ''hellomoto'' screen on Razor V3c when turning on phone
your firmware is corrupt, the only way to revive your phone is re flashing it.Its hard to do, and by doing it wrong may damage your phone. To safely retrieve your phone is let the experts do it or go to a near cell repair shop and let them help you out,
if you want to do it your self, try this
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Nov 25, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Display Screen Blinks
the firmware on the phone need to be reflash , so take the phone to a mobile repair shop and have them do it for you there.
Apr 01, 2008 | Motorola Mobility V551
MOTOROLA V220 BOOTLOADER PROBLEM
this is the programing mode where the software was originally loaded. Try to remove the battery while the phone is turned on. Sometimes this will reload and allow the phone to work normally. If not contact motorola for warranty info.
Feb 02, 2008 | Motorola Mobility V220
Doesn't turn on!!
you need to try and get into the boot loader to see if you can flex/flash it from there. a new flex should solve the problem, unless there is physical or water damage to it. It could also be a defective battery. Are you positive the battery works? Did you do any kind of upgrade on the phone? played with it's firmware? On flashing - http://wiki.howardforums.com/motorola/index.php/How_to_flash_with_RSD_lite Flexing is done the same way Good luck
Jun 24, 2006 | Motorola Mobility V710
Motorola Mobility V600 Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
