Question about Boating
Evinrude 65hp 65853B Shift lever stuck
I recently bought a boat with a 65HP Evinrude motor that i'm attempting to get running. I've disconnected the shift cable and the shift lever it attaches to seems to be stuck in place. Am i missing a saftey feature/switch? Since it sat for a while could it be corroded to the point of not moving at all? Any info would be greatly appriciated. Thanks
Fabrice Wolters
    Sergeant:
  • 331 Answers
Yes, it will be corroded. Just have to find where.
Look to remove the cable from the link arm in the motor.
Can you now set the throttle lever in fwd and rev? Does the cable moves? If Yes, it's in your engine that you have trouble. If no, disconnect cable at the throttle lever and re-check...
If it's the engine: Remove the gearhousing. If now you have movement, the gear housing is stuck ( water inside that has corroded everything, good luck)
If still no movement, check the linkage, you'll have to remove the engine block from the exhaust plate.
The best is to find a service manual to get the right way to disassemble and reassemble...
Posted on Nov 14, 2017
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: 2000 jetta does not shift into reverse
is this going from park?? if so, it could be the module inside the cover where the shifter is...this is the piece that tells the shifter when the brake is pressed and allows it to shift.... check that out and let me know if u have anything else....
Posted on Jun 20, 2009
csmock132
Clint Smock
  • 4669 Answers
SOURCE: My 2000 Intrepid became very hard to put in and
It is the shift cable. It is a dealer item, about 70 dollars. Plus there is a new bracket they will sell you to cure the problem.
Posted on Apr 21, 2010
Anonymous
  • 5 Answers
SOURCE: How to disconnect shifting lever on a 1994
This is a long shaft, should disconnect just below carburetor. Pull all the way out of mid section.
Posted on Oct 02, 2010
Tri3mast
Robert Taylor
  • 747 Answers
SOURCE: What are the head bolt torqe specifications on a
The head bolts are torques to 16.7 lb ft run the bolts in to just snug then starting in the middle and work outwards in a rotational pattern. After running the engine up to temperature shut it off let sit for a few minutes and then re-torques the bolts again in the same pattern.
Posted on Dec 02, 2010
Testimonial: "Thanks!"
Anonymous
SOURCE: The transmission shift lever on the column feels diconnected.
This is probably to late to help the original poster but it may help others. My 2001 Tribute did the same thing. I would check the connection under the hood first because it is easier to reach. It is between the airbox and firewall directly in from of the driver. It will probably require a flashlight to see but that is where mine was disconnected.
Unfortunately before realizing that I removed the black plastic shroud from the bottom of the steering column. The shift cable connects underneath the the column a few inches in front of the steering wheel. It is connected with a push on connection.
Both connectors have a rubber gasket inside the loop connector that dry rotted in the engine bay. I'm sure it would be easier to simply run a new shift cable but I was strapped for cash at the time and simply hooked it back on and placed a spring clip washer outside it to hold it on.
I hope this helps everyone!
Posted on Mar 08, 2011
What oil do I use in a 1972 Starcraft Boat? Thank you.
Back during the time these were made, you would be advised to use a 30 HD.
This oil would be appropriate for all use except real cold weather, when a 20W-20 would be better. ( below 40 degrees farenheit)
(Do not use a non-detergent.)
A few years later, the recommendation changed to 10W-30.
Jan 11, 2016 | Boating
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Ignition will not turn off on my 65hp. johnson outboard
Did you check the ignition switch?
Aug 17, 2013 | Boating
SELVA 65HP ENGINE
DRIP FUEL INTO CYLINDER(S)......IF THIS CAUSES MOTOR TO START...THEN STOP AGAIN YOU HAVE A CARB FUEL METERING ISSUE
Jul 08, 2013 | Boating
What are the head bolt torqe specifications on a 1990's Suzuki 65hp outboard boat motor?
Nov 27, 2010 | Boating
My spark plugs are not firing on my 1973 65hp mercury
check to make sure plugs are ok,next check plug wires ,last check the coil.
Jul 22, 2009 | Boating
Boating Logo
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
