SOURCE: playing my music, then amp goes out? anyway to fix it?
Looks to me like u are having a power problem. Check if power is going to your amp, if yes, check the fuse on the amp. If ok, check the powersupply section for any damage components and replace.
SOURCE: my pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
SOURCE: kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
SOURCE: my music is playing very low and the bass is fine
It sounds like the gain on one of your channels need adjusting
