Question about Fuji FinePix A360 Digital Camera
When I plug it into the computer the green light flashes
Posted by Lillie on
Green light flashing on circuit board
Is there any problem with it?? I think you may be referring to the LAN adapter's blinking green light, if if is blinking while the computer is on and an ethernet cable is plugged in it is perfectly normal... otherwise please elaborate on the problem.
Jan 08, 2014 | Dell Dimension XPS PC Desktop
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
MY COMPUTERS front and back green light is flashing green
you can remove your side cover,and unplug everything from your power supply. then if you plug in your computer and the light still flashes it's your power supply. If not it's something that it is powering. Most likely it's your motherboard. I had this happen to me when there was a power surge/ outage and my computer wasn't even on.
Aug 06, 2010 | Compaq Presario sr1111nx 2.53GHz Celeron...
Computer won't come on.
RAM need to change., see wheather any wire short circut.
Dec 09, 2009 | Computers & Internet
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Oct 30, 2008 | IBM ThinkPad T22 2647 Notebook
Green Flashing Lite
replace the power source then ......its obviously faulty
Jul 19, 2008 | HP Pavilion a830n (PP166AA#ABA) PC Desktop
Fuji FinePix A360 Digital Camera Logo
22 people viewed this question
Top Fuji Cameras Experts
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
