Sharp Aquos LC-15E1U 15 in. LCD EDTV Logo
A
Anonymous Posted on Aug 27, 2013
Where is the reset button on Sharp Aquos LC-15E1U
5 Related Answers
A
Anonymous
  • Posted on Jan 25, 2008
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Anonymous
  • 405 Answers
  • Posted on Nov 06, 2009
SOURCE: Sharp Aquos LC-3237U keeps turning off what could
Check if the power menegment is enabled. Go menu> power control ind see if NO OPERATION OFF is enabled.
Chi Chu
  • 8457 Answers
  • Posted on Dec 17, 2009
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
Chi Chu
  • 8457 Answers
  • Posted on Apr 05, 2010
SOURCE: Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Anonymous
  • Posted on Apr 11, 2011
SOURCE: how to reset sharp aquos lc-32l400m?thanx before
Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
How to reset a sharp aquos?
Hold VOLUME UP and CHANNEL UP buttons in while plugging set into power.
TV comes up in service mode.
Press CHAN + or CHAN - to select an adjustment that you want to change
Press VOL+ or VOL- to adjust
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
How do I stop the CC on my Sharp Aquos
Sharp Aquos LC-37G4U
Try the remote.
On the remote is a button labeled CC near the bottom.
Press the button to access a menu to switch off. Each time you press the button it will toggle among the choices.
If the tv has problems, try turning it off and unplugging for a few minutes to reset the EPROMs.
Plug in and turn on. Repeat the above.
If you want to change the size/color of the font you can get into menu mode by pressing the menu botton in the center of remote.
Next use the and > arrows to get to OPTION menu.
Use the ^ and v arrows to get to the Caption Setup menu and press Enter.
Toshiba 42 lcd
All the Toshiba's I've seen come through my door for service are 14 months and newer. He's correct. Very poor for parts availability.
Aquos turned itself off and won't turn on again
hi....Your micro chip is faulty check the voltage comming out of the 42nd leg it shuold be 13 volts dc if you are not getting that voltage replace the microchip.and the eeprom IC....
thank u rate me!!
HDMI connection problem
Your TV doesn't like your laptop I guess.
There should be 2 reset buttons behind your TV.
Press the reset button first.
If that doesn't work, try the system reset button next.
If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
Good Luck
2answers
Aquos 37" LCD
I'm having the same problem with my 32" Aquos.
Karen
Raleigh, NC
19helpful
5answers
Black rectangle appears on screen
Check the settings for the CC (closed captioning) on your menu. Make sure it is turned off - if it is set to TEXT mode you will get a black box in the middle of the screen. Also look for a button on your remote labeled "CC"
1helpful
Problem with power on
No you have a power supply problem on this TV set. Pretty common for this make as the capacitors and the regulator circuit In my opinion is way under rated, as there is no head room on the power supply in cases of when the screen turns really bright, or you could have a ballist problem in your backlight circuit. All of these are non repairable by the user unless you have solid state repair experience. Good Luck
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
