Question about Sharp Televison & Video
I hook up the red and white RCA plugs to input 1 on tv to audio output of memorex front sound system model#MIHTS3202 and don't get any sound through the memorex speakers. I don't know if this matters but the tv is getting the video signa from a dish network receiver.
Posted by pdriver on
Mark
    Problem Solver:
  • 6 Answers
Plug the rca into the dish reciever, and into the surround sound, your audio isnt coming from the tv, its coming from dish.
Posted on Apr 11, 2009
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
What cable goes from the tv to the system so I get sound from both the system and the television
On the back of the TV, there should be a set of RCA audio output jacks. Colored red (R) and white (L). Buy a dual (red/white) RCA cable in the length you need. Plug it from the TV's RCA audio outputs to your stereo receiver TV input, or any unused input (but not phono/turntable in). Select that input from the choices on the front panel of stereo receiver.
Now, the RCA audio output from the TV might have a choice of variable or fixed level out. Adjustment is via the audio properties in the setup menu.
Variable means when you adjust the voulme on your TV, it affects the level going to you stereo receiver.
Fixed means that the audio output from the TV is a steady signal, and the adjusted volume on the TV does not affect the level to your stereo receiver.
I would choose FIXED. Hope this helps.
1helpful
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
How do I hook my Memorex Model MVD2016 to an Emerson Model EWT19B3 TV
You need to get an RF modulator if you want to connect to the antenna input on the back of the TV set. You can use the composite output of the Memorex - the yellow cable output - and connect to the video input on the front of the TV, and use the red or white output from the DVD to connect to the audio input on the front of the TV. You will have to press the 'game' button on the remote to select the front audio/video inputs.
tom
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
1helpful
How do I connect Durabrand home theater system to my TV with built-in DVD player? I also tried to hook it up to the game cube for my son...but could not get it to work. The only way it is working is by...
One way is to run a set of red white rca stereo audio cables from the back of your tv's red,white audio out plugs to the audio in plugs on durabrand hometheater system which are colored red and white. Most tv's will output audio signal automatically but some tv's like sony you need to go into menu of tv and under sound settings switch audio ouput to audio system if the sound doesn't come out automatically. Make sure you but durabrand hometheate system on correct input which should be labeled on back of durabrand system where the red and white audio in plugs are. Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
How do I get sounds when I use the red green blue rca hook ups?
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Televison & Video Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
