Question about Karcher K2.26 Electric Power Washer
Karcher pressure washer won't start
Power is reaching the machine (the 'tell tale' light is on at the switch)
Water is going through the machine, but only at mains pressure.
The lance is not blocked.
Detergent flow is OK.
The pump appears to be dead.
Posted by ralph_birtwi on
Martin Grech
  • 94 Answers
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
Why won't my brand new karcher k2700 psi pressure washer start
no water connected to the machine
pull the trigger to allow pressure to build up or to switch the pump on
Oct 26, 2016 | Karcher Garden
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
My karcher 2600 pressure washer gcv160 keeps cutting off?
Check out this link, it should tell you how to fix the problem that you are having with your machine
http://www.wmpcs.com/blog/?p=72
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Jul 27, 2009 | Karcher K2.26 Electric Power Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
A FRIEND HAS LENT ME THIS WASHER, BUT HAS T GOT A MANUAL
Best to run hose for a minute before connecting to machine to clear any debris from hose, plug hose to machine and pull trigger to run water through, plug into power and away you go, when trigger not pulled unit goes into bypass mode, it is advised to not leave in bypass for more than about 5 minutes, this model is light and can easly be over heated so I would advise to switch off at machine and run water through every 20 minutes to half an hour for at least a couple of minutes, after you have finised using unit, switch off at machine, disconect water and power then squeeze trigger to release pressure from pump.
Apr 20, 2009 | Garden
Karcher K2.26 Electric Power Washer Logo
8,473 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
