Question about Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
Posted by Steve on
Holly
    New Friend:
  • 29 Answers
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Posted on Aug 27, 2013
5 Related Answers
Anonymous
SOURCE: Sony projection tv Model KP43HT20 won't turn on
Does Sony offer any kind of recall for this problem? It seems to be a common problem for this model of tv.
Posted on Oct 13, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Posted on Aug 30, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: TV turned off by itself and now blinks red led 6 times
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
http://servicemanuals.vstore.ca/
Posted on Feb 01, 2008
Anonymous
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 04, 2009
Anonymous
  • 41 Answers
SOURCE: Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Posted on Apr 16, 2009
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Hello, I have an issue with a SONY KLV-40BX400, the TV turns on, displays the sony logo and plays the power on sound then turns off and turns on a few times and then doesnt turn at all and
If it is PLASMA TV.....
brandon barnes mentions..there is usually nothing physically wrong with 6 blink tvs..you need to reset the TV using the original remote
Not sure if the fix mentioned below is appropriate for your TV Sony eSupport Electronics Drivers Software
Aug 03, 2016 | Sony Televison & Video
I have Sony Bravia model KDL-55NX720 & it won't turn on.It has 5 blinking red lights.According to a diagram that I found for this TV, I have replaced the TCon Board and the LED Panel. Any suggestions?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 14, 2016 | Sony BRAVIA KDL-55NX720 55" 3D LED-LCD TV...
Is it a problem of the inverter board ?
Jun 12, 2016 | Sony 40 KDL40BX420 LCD TV
My sony tv shuts off after 30 sec or so and blinks 4 times
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 12, 2016 | Sony KDL60EX700 60 in. TV
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
Sony Grand WEGA KDF-55XS955 55" Rear Projection HDTV Logo
276 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
