Question about ASUS LCD Monitor
Change 720p 1080p - ASUS LCD Monitor
Posted by johannes on
Simon Jarslev
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 102 Answers
Are you using a Nvidia gfx card? If so, then go into the setup menu (comes with all Nvidia drivers). in the "screen size" menu, there should be a list of the supported screen resolutions. Do remember that the cable you use (HDMI, Display Port, VGA, DVI etc. ), also has an effect on the screen resolution.
Posted on Apr 16, 2014
How do I change resolution from 720 to 1080
Hi, You don't change it. Your t.v. will play at 1080p if it is a native 1080p t.v. and it is receiving a 1080p signal. If it is receiving a 720p signal. Then it will play at 720p. If your t.v. is native 720p and receives a 1080 signal. It will scale down the signal to 720p.
May 13, 2016 | Televison & Video
How I get a 1080p display. I only get 720p
You need to have a 1080p source. Most TV channels broadcast in 720p. Otherwise, a bluray player hooked up via HDMI will give you 1080p. The TV will switch to the correct resolution automatically.
Feb 18, 2016 | Westinghouse 48 1080p LED HDTV
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
I need to change the resolution to 1080 on a vizio D650i-B2
The resolution for TV's is auto sensed by the content being sent to it.
If you are playing a 720p file, you cannot make it 1080p. 720p vs 1080p Can You Tell The Difference Between HDTV Resolutions
Apr 26, 2015 | Vizio Televison & Video
Shows 720p but should be 1080p seiki se24ft01
This will be ether the zoom button on the remote or If you go onto the menu screen settings
Jan 04, 2014 | Seiki 24" Class 1080p 60Hz LED HDTV...
HI...HOW DO I CHANGE MY TV FROM 720 TO 1080?
U talking about tv show broadcasting in 720p,u wanted to changed it into 1080p.U can't do this,u only get what the tv stations modes,what ever modes they put out only.Put out 720p u get only 720p,if put out 1080p u get 1080p only.
Jun 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
How to change my display setting from 720p to 1080p
The resolution is dictated by the video source, if it is fed with 720p, you will get 720p res, feed it with 1080p will display 1080p, just like your PC monitor which is controlled by your PC video card resolution setting, not at the monitor.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 07, 2010 | LG 32LD550 32 in. LCD HDTV
How do I change the resolution from 720p to 1080p
If your Sony TV is designed to display 1080P resolution - you don't need to do anything. It does it automatically synchronizing with appropriate 1080P signal source.
If source does not produce 1080P (because it can't or settings are wrong) TV won't display it.
Regards.
Russ.
Aug 12, 2010 | Sony Televison & Video
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Call of duty 4 1080p
First off, Sony doesn't make Aquos they make Brava. Sharp makes Aquos. Secondly, I am unable to uncheck 720p how do I do  this?
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
ASUS LCD Monitor Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
