Magic Sing Along Consumer Microphone Logo
Question about Magic Sing Along Consumer Microphone
Can I hook the (yellow cable) video to the tv and the audio (red and white) to my blue ray for sound output. I don't have an amp. So i'm guessing my blue/ray home theater system is my amp.
Cesar Caldito
    New Friend:
    Problem Solver:
  • 9 Answers
Of course you may. If so, minimize tv sound by decreasing tv volume and simply let your sound system be your amp.
Posted on Aug 30, 2016
1 Related Answer
Anonymous
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
We have no sound when we play a disc..picture is on.
How are the DVD player and the TV connected?
Coax cable? (Carries both audio & video.)
Composite output? (Red & white for audio, yellow for video)
Component output? (Red & Blue & Green for video, White & Red for stereo audio)
DVI output? (Video only)
HDMI output? (Carries both video & audio)
I need a manual for a sanyo DWM-3000.
What outputs does the Sanyo have?
Composite output? (Yellow, with RED/WHITE stereo audio)
Component output? (Red/Blue/Green video with Red/White audio)
HDMI output?
Coax? (Audio & video combined)
What inputs does the TV have?
Coax?
HDMI?
Component?
Composite?
How do i connect a Blu-ray player to my TV
It should connect best to the one with blue,green,red and then the two for sound--red and white---This is component hookup.
once connected you select the input via the remote or menu..
The ones with the yellow, white and red are composite (yellow is video and color and red/white are audio---doubt it will work off blue ray unless similar outputs on that.
Trying to hook up my daughters dvd and tv. I've got one set of cables with yellow red and white connections,where do they go?
Red is for Left Audio Output, to TV Left Audio Input
White is for Right Audio Output, to TV Right Audio Input
Yellow is for Video Output to TV Video Input
You should see the same color coded RCA jacks on the rear of your TV unit. Just match the inputs to the correct device ie: Video 1, Video 2, etc
Hooked it up to a blue ray player, no cable at all, just the blue ray, and i get no sound from the tv, just a picture
To connect the Blu-ray player to the TV, connect the Video OUT of the Blu-ray player to the VIDEO 1, VIDEO 3, VIDEO 4 port on the TV using the "RED/WHITE/YELLOW" Composite cable to get both audio and video. You may also connect the "Component OUT" port of the Blu-ray Player to the VIDEO 5 and VIDEO 6 port on the TV using the (Red/Blue/Green/Red/White) Component cable to get both audio and video from it. If you have any questions on connectivity, you may wish to reply with your query.
Thanks,
Pradeep
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
1helpful
Can you put a phillips dvdr610 onto a television with built in freeview and then record from it. If so how?
If your TV has an OUTPUT MONITOR Output Jacks, Yellow, (Video) Red (Audio) & White (Audio) FEMALE RCA Jacks.Then these will output WHATEVER is showing on the TV screen. And can be used as an Output for any Recording Viewing device. There will be other, FEMALE RCA Jacks,AV, Yellow, (Video) Red (Audio) & White (Audio) and possibly also The Composite Video, Red, Green, Blue, all Video, These are INPUTS, they will be there also. Make sure.
2answers
I spent the last hour on the phone with tech support for my local cable company. after the duration, we came to the conclusion that there was in fact, not a space for the red, yellow and white chords....
Without seeing anything, the yellow=video, the red and white=audio. The yellow/video "output" of the cable box goes to the yellow/video "input" of the TV. The red and white are the audio that go from audio "output" of the cable box to the audio "input"of the TV. I don't know what the Cable company was telling you???? The cables are "RCA" and give you the worst clarity for a picture. If you cable box has three output ports colored Red, Green, and Blue ("Component') and you TV has the same three as inputs, that will make your picture much better. If you can hook it up with the component jacks, you will still need the audio RCA (red and white) between the two units. I hope this helps.
2answers
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Top Magic Audio Players & Recorders Experts
W.L.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
