Whirlpool GX5FHTXVY Energy Star Gold 24.8 Cu. Ft. French Door Bottom-F Logo
Anonymous Posted on Aug 27, 2013
The refrigerator isn't getting cold.... It is about 2 years old
Jim Akins
Level 2:
Champion:
  • Expert 201 Answers
  • Posted on May 07, 2014
 Jim Akins
Expert
Level 2:
Champion:
Answers
201
Questions
9
Helped
64106
Points
445
IF the freezer is still cold, you have an air flow problem. This is usually a defroster problem or the fan in the freezer has quit.
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My Kenmore upright freezer is not working properly. Model: 253.9208212 Freezer still has power to it and the fan is still blowing cold air around but the freezer is nowhere near as cold as it should...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Side byrefrigerator runs but not cold. Freezer is
take everything out of it, and let it thaw for 24 hours, using towels and whatever to clean up the water......then plug it back in, if it still does it, like 2 days later, it's broke, if it doesn't it was just the coil in the back that froze up. Happened to me.
2answers
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 • Freezers
Won't get cold enough
welcome mvernon6
How old is your Freezer ?
Make and Model
This can be anyone of a host of problems,
1. Thermostat bad
2.Freon coolant low
3. Coolant leak.
4.Are the coils on the bottom of the freezer behind the grille or in the rear of the box?
These are the narrow black tubes that run parallel to each other, back and forth.
They carry the coolant to and from the compressor!
If they are under the freezer, then they may be covered with years of dust and lint and in need of a refrigerator brush down there to gently clean the stuff out!
Air needs to pass over them as the fan sucks it in through the front grille to cool them off.
The brush is $8-$10 at the hard ware store.
I hope my suggestions help.
Let me know how it goes.
Bless You Huuum
Please do not forget to leave a rating.
Below is an article I read about these things
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 21, 2008 • Freezers
2answers
My freezer is about 2 years old, but has been in storage for about a year and a half. The green light comes on, and the motor is running, but it will not get cold or even cool.
Hi ndntwiggy,
Ngafm at your service
Your said,your freezer is about 2 years old, but has been in storage for about a year and a half.
And the green light comes on, and the motor is running, but it will not get cold or even cool.
When a compressor is not run for more than a year, or 2 years there is a possibility that the seals dried out from non use and the freon leaked out.
Compressors have oil in them that when run even once a month will lubricate the seals and keep them soft and moist! .
Just like in the older cars from the 1960's or 70's the air conditioners had to be run once a month even in the winter to keep the seals lubricated or they lost the freon!
Then they started to make the defroster turn the compressor on as to lubricate the seals every time it rained or snowed and you needed the defrosters and this serviced the compressor as in todays cars.!
So you need service to fix it and more than likely it's out of freon refrigerant .
Let me know your end results.
ngafm
Please give me a good rating for my accurate advice,
before you sign out of our site.
thank You ngafm
Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Jul 06, 2008 • Freezers
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
