Question about Canon Office Equipment & Supplies
Vertical black line on side of copies only when using autofeed
Canon imageclass prints out vertical black line down side of copy only when using autofeed. When feeding manually, there is no line.
  • Anonymous Mar 15, 2014
    vertical shaded line print left side
  • Anonymous Mar 23, 2014
    black striped vertical line in canon ir 5000
  • 227 Answers
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Posted on Apr 11, 2009
    New Friend:
My Canon Imageclass D861 had a black vertical line when i used the autofeeder, but when i manually feed it, there is no line. I've been trying to fix this problem searching the internet for weeks. I haven't been able to use the autofeeder for a month. I tried cleaning the rollers, even unscrewing stuff trying to clean everything. I wiped down the glass, but still there was that vertical line that frustrates me. When i finally read 20YrsCompExp's solution, I gave that glass another try. I cleaned the left side of the glass at the top and bottom corners and I've seen a little piece of whiteout tape that was accidently stuck on the glass. I scratched it out and tried to find every little pieces of anything that was stuck on the glass. So basically i just cleaned the glass up and down left to right spotless. Thank you 20YrsCompExp for that tip =]
Posted on Jul 29, 2010
6ya staff
SOURCE:
A vertical black line appear on each paper when the document feeder is used to make copies; such vertical line does not appear on papers when copying on the glass surface. How do I resolve this...?
when you open the copier platen cover, left of the copy glass, there is small narrow glass, which is used when you make copies from ADF. Over that glass is plastic protective sheet. Remove it and clean, also clean the glass. Use glass detergent and after cleaning dry it!
Even the smallest dirt can cause lines!
Hope that helps!
Apr 25, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
Line is appearing on the printed copies. How to
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Dec 07, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Black line down paper
Please clean the scanner bed with clean cloth and then scan
May 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Feb 28, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D780
Clean the platen glass and make sure the isn't any debris or ink on it, especially by the roller. If you make a copy thru the ADF while the ink is still wet it will deposit on the glass.
Jan 08, 2007 | Canon imageCLASS D780 All-In-One Laser...
621 people viewed this question
Clive
Clive
old marine
old marine
Ekse
