Question about Canon EOS Rebel XSi Digital Camera
Won't focus properly on auto focus. - Canon EOS Rebel XSi Digital Camera
Posted by Karen Garland on
CraigNewman
    Problem Solver:
  • 15 Answers
Depending on your lens, you may have an AF/MF switch. Make sure it's set to AF for Auto Focus. Try increasing your light levels. Does focus work in a good light setting?
You should have a button that looks like a matrix. Press this button to set your focus point. Use the joy-stick like wheel to select the focus point. Press it to select Auto Focus points.
Posted on Dec 27, 2014
1helpful
2answers
18-55mm lens wont auto focus
If the lens will focus on manual focus but won;t on auto focus you may have a ribbon connector failure in the lens. This ribbon continually flexis as the lens moves in and out. Over time this can break and will probably need to be replaced. All good camera repair shop should be able to do this for you and this remady is one of the cheaper repairs to photographic equipment
Canon lens won't focus
If it focuses OK in manual but not in auto then you may have broken ribbon cable in the lens.
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
2helpful
2answers
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
2answers
Auto focus is not working properly and will not
You want to charge people for a membership to get answers from your site
but you want me to "tell you how I did it" for free. Hmmmmmm?
Canon EOS Rebel XSi Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
