Sony PlayStation Portable (PSP) Console Logo
Question about Sony PlayStation Portable (PSP) Console
Internet acess points
When i type in a website a message pops up and saids a connection error has occorred the access point was not detected.
Posted by squrial on
  • squrial Sep 09, 2007
    Who the heck is Squrial your so stupid!!!!!!!!
Anonymous
  • 752 Answers
That means that it is not finding the wireless network signal. Are you within range of your access point?
Posted on Sep 13, 2007
How do i resolve the issue of Brother Printer Error Code TS-07?
The Brother Printer Error TS-07 occurs when your brother printer can't detect a WLAN access point or router that has WPS or AOSS enabled. You can fix this Brother Printer Error Code TS-07 easily and quickly on your own by following the stepwise procedure specified below.
The step by step process on how to fix Brother Printer Error TS-07 is as follows.
  • Firstly, ensure that your WLAN access point or router supports WPS or AOSS. You can check it either by looking for icons present on your router or by checking the documents that were provided with your WLAN Access Point or Router.
  • If your brother printer is WPS or AOSS enabled, configure your wireless settings using automatic wireless mode (WPS or AOSS).
  • Ensure that you operate both the brother printer and WLAN access point or router.
  • For an undisturbed internet connection, place your Brother Printer within the range of your WLAN Access Point or the Router.
  • Don't keep any signal emitting objects like mobiles around your brother printer or the WLAN Access Point/Router because these objects may disturb your WLAN Router or Access Point.
  • Now press the 'Menu' option on your brother printer and then select the network and then tap on 'OK.'
  • Now, with the help of the up and down keys on your printer, check for the WLAN network, select it and then click on 'OK.'
  • Look for the WPS or AOSS option, select it and then tap on 'OK.'
  • If the message 'WLAN Enable' appears on the screen, choose the 'accept' option. By this, the wired network setting will be disabled.
  • If 'Network I/F switched to wireless' or 'Enable WLAN' message is displayed, click on the 'OK' option.
  • Now hold on the WPS or AOSS button present on the WLAN Access Point/Router for some time. You have to hold the button located on your WLAN Router or Access Point.
  • Then, press the 'OK' option. Now your Brother Printer will automatically detect the mode of your WPN Access point and connect to your wireless network.
  • Now, on your printer's LCD screen, the WLAN report will be displayed and it will be printed automatically.
  • If at all the connection fails, then check the error code on the printed WLAN report.
1helpful
Could not find any compatible access point nearby. check the connection settings in the menu "internet" and try again. For help, visit the web site support.nintendo.com ... Error: 051110
Welcome to fixya.com we are here to try and help you with your nintendo Wii
This error message you are getting is indeed a error timeout that resulted in a mis configured access point or did not find a access point.
You might want to check your security settings in your router by accessing the router via browser using a computer at 192.168.1.1 putting in the user name and password as well.
You want to select 64 bit security encryption for your router so the Wii can understand it. Most AP's "acess points" use WPA or TSKIP witch the Wii might not see as use able.
You also want to make sure your access point is broadcasting as well.
if you need additional helps on this please respond with the type of router you have along with the model number.
Thanks for using fixya.com
regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
When i turn on inter net appear (403 error permission failed)
faulty configuration of the phone connection . please call your service provider- call center- and make this request to confirm the status of your connection. If not correct the link to be added to your phone to allow internet browsing.
You have not mentioned the phone make and service provider.
Jan 13, 2011 • Cell Phones
Please i would like to know how to configure the alvarion radio wireless acess point . thanx!
YOU CAN SEE YOUR DEFAULT GATEWAY IN NETWORK CONNECTION STATUS COPY THE NUMBERS, OPEN INTERNET EXPLORER TYPE THE NUMBERS IN THE IE WEB BROWSER THEN ENTER.
WHEN ASK USER NAME AND PASSWORD.TRY THIS USER-NAME admin PASS admin OR user-user.
note; you cannot open it in another web browser like Firefox chrome etc. just IE only
1helpful
2answers
I don't know how to reinstall the linksys access point!!! Our wireless network that we made simply disappeared, so I'm trying to re-make one. However, when I tried that with a flash drive, it couldn't work...
T
o access the Access Points Setup, and the LAN IP address has not changed, then computer must have an IP address of 192.168.1.XXX. If the Access Point is plugged in via Ethernet to a Linksys Router and the computer is also connected a Linksys router via Ethernet, then the PC should already have a correct IP address (unless the LAN IP Address of the Router has been changed). If unsure, please assign the computer a Static IP Address so it will have an IP address in the same range as the Access Points IP Address.
If the Access Point is being connected to a hub/switch/router via Ethernet, then use the cable that was provided with Access Point. If the Access Point is being connected to the computer directly, then a Cross Over cable must be used. Cross over cables can be purchased at most electronic stores.
    Remember: When ever a change is made in the Setup of the Access Point, the Apply button must be used to save the settings to the Access Point.
  1. Open a web browser (such as Internet Explorer or Netscape)
  2. When the browser opens, go to the "Address" bar and input the IP address of the Access Point.
      Default IP addresses:
    • WAP11 v2.8 - 192.168.1.251
    • WAP54G v1.1 - 192.168.1.245
  3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Access Points password (The default password of a Linksys Access Point is admin) into the "Password" field.
2answers
I have nokia suernova 7210 phone i can acess gprs but icant connect to my pc for acess net.when i attempt there is a message packet data connection not avaliable what can i do
Use Nokia PC Suite to access net on PC. Download PC Suite from 'www.nokia-asia.com', install it on your PC and enjoy surfing. Without PC Suite, Nokia 7210 Supernova does not work for net access on PC, as per my personal experience too.
Aug 04, 2009 • Nokia 7210
I have a Wireless Netgear A23A50 and want to place a pass word on it for access.
First acess your router with following link
http://192.168.1.1
or
http://192.168.0.1
type username as "admin" and password as "admin" or blank or "password"
then set your internet connection type as WEP then set encryption key it is your password when you clik on connect on computer.
First connect your router to computer with ethernet cable but if it is in wi fi network right now no need of cable.
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
7helpful
14answers
WIFI does not work: internal error 00000001
dont worry its no problen sony did not encode the higher versions it should say no network found but but it is the same thing so dont worry
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
Alexander
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
