Question about Onkyo TX-DS575 Receiver
No sound output
Amp switches on ok, modes can be changed but no sound is heard. sometimes when switching modes sound comes back but if sky is paused, sometimes sound goes again.
Posted by nargar on
sonofspy
    Habit-Forming:
  • 36 Answers
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Posted on Apr 19, 2009
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
Cannot Power Up, Sometimes can
i had a real nice yamaha natural sound receiver and the relay that switched it on went bad a lot..... try the relay???
Apr 26, 2010 | Yamaha RX-V650 Receiver
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Watching Sky HD, sound ok in 5.1, then adverts
This is a problem with the digital lock.
What this means is that your receiver is suppose to sense the type of digital audio feed, during programming it receiver the 5.1 and decodes it, then the feed switches to a 2 channel signal and the receiver's DSP hangs up. I bet if you change inputs then change back it re-locks and works fine until the signal changes again.
This happened on some of the Harman receivers, I can't recall if the 130 had an RS-232 port on the back. If so you can go on www.harmankardon.com and download a firmware update that may help with this problem.
FIRST
Cover the basics, unplug and replug the receiver.
Second write down all your settings, perform a processor reset as outline in the back of your manual and reprogram the receiver.
I warn you if the update fails your receiver will not be worth repairing!!
Cheers,
Kevin
Jan 27, 2010 | Harman Kardon AVR 130 Receiver
I have a phonic powerpod 7. the speaker connections are A & B main 1 & the same main 2 in the middle there is 1 1/4 jack socket that says bridge. it says dont connect any speakers to a or b when...
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Jul 01, 2009 | Audio Players & Recorders
How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
Start up problem.
I suggest you look at the Horizontal output transistor, when it goes short the supply is in protection mode, it is pointless reading voltages at this stage, check the transistor located close to the Horizontal output (Flyback) transformer and normally mounted on a large heatsink. Check the caps in the primary power supply stage....hope that helps..Phil
May 19, 2009 | Televison & Video
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Onkyo TX-DS575 Receiver Logo
1,597 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
