SOURCE: i have error 0210 stuck key 01 on an IBM
My key R is stuck. And some some letter keys become numbers once I press them
SOURCE: error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
SOURCE: how to fix an error
One of the keys on the keyboard is "stuck" in the "down" position, so that it keeps sending the same character. Quickly press/release each key, several times, to see if you can "unstuck" that key. Or, replace the keyboard.
SOURCE: ERROR 0210: Stuck key 7B,
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
SOURCE: ERROR 0210: Stuck key 7B Press
There are issues with
the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery
area) and F12(boot device
selection). Just
a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold
down for a while rather than multiple
press and release. I
hope this would resolves your ERROR 0210: Stuck key
