Bosch WF6 2005 washing machine was uninstalled by a tenant in my house. I want to reconnect it but have noticed the hot water feed pipe on the wall behind seems to be 'capped'. Does this mean my machine is a cold water feed only? I hope so!
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
