Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman''; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}My digimax d103 turns on but the lens wont extend fully atturn on and the picture is blurred. But if i use the zoom option all is ok andit takes a good picture what can i do about the problem?
you do that by trying to take apart the barrel an look for any signs of stickyness. Remove the stickyness and if it still does not work, your motor may not be workingyou do that by trying to take apart the barrel an look for any signs of stickyness. Remove the stickyness and if it still does not work, your motor may not be working
You can't post conmments that contain an email address.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them. And here's a video summary of the steps:
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
the problem is with lens.this sometimes happens if cam becomes victim with water. there is some buzzing noise when the shutter of lens gets opened or closed. please clean the lens with the solution once.then you can make out of blurs.
This product has a 2 year warranty, unfortunately I lost the original till receipt, but managed to get the transaction details from PC World (I bought it in Dec 2006). The Samsung telephone number for the UK is 00800 12263727 - I have now sent it off to them for repair (recorded delivery) to the service centre at Samsung Opto-Electronics UK Ltd, Samsung House, 1000 Hillswood Drive, Hillswood Business Park, Chertsey, KT16 0PS - On talking to their service team, when the camera "Beeps" 3 times and turns off it is faulty, and will need to be repaired - So no easy fix - It's over to you now!!
Hello
This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended.
Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore.
Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
Thank you and sorry to seek stupib but how do i solve it ?
