Question about Goodman CKL24AR24 Air Conditioner
I have a goodman ac unit. The model # is CKL24-1H. I recently replaced the capacitor. The fan now runs continuisly. It kicks on like it is supposed too, but even with the system off the fan runs. I think I have a wiring issue but not sure
william simpson
    Genius:
  • Goodman Master
  • 1,363 Answers
Fan relay stuck in or thermostat set to fan on.
Posted on Aug 14, 2015
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: Inside blower not starting every time
This should have a time delay sequencer for the blower in the a/c mode. These are bad about being interminent in the a/c mode and also in fan. I have had some that would freeze up and I would get there and the fan be running. Thaw out and check and everything be ok. Got to cycling the fan on and off and sooner or later it would get where fan didn't come on. After replacement the customer didn't have anymore problem. Check the rely, looks like a heat sequencer but mounted on plate to blower compartment.
Posted on May 15, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
Anonymous
  • 182 Answers
SOURCE: Goodman Furnace/AC unit not working
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Posted on Jul 04, 2008
Anonymous
  • 540 Answers
SOURCE: Goodman CKL60-1 Condenser Fan Runs OK, then stops
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Posted on Aug 25, 2008
Anonymous
  • 4 Answers
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Posted on Jun 18, 2009
I have a Goodman model # CK30-10.. The fan on the outside unit runs sometimes. I notice when I first turn the unit on, the fan will run 5 to 10 minutes and then shutoff. Is this a capacitor or relay?
Not a relay. It is probably the capacitor. Also may be that the motor bearings are dry and the motor will need to be replaced. Its always less expensive to try the capacitor. Certainly work safe when it comes to run capacitors!
Jun 25, 2015 | Goodman Heating & Cooling
Ac compressor will not start
Hello, sounds like a faulty capacitor. Check the capacitor to see if it is puffed up at the terminals. It will be located inside the outside unit and looks like like a can that is oval or round.
Jun 17, 2012 | Goodman Heating & Cooling
Heat/AC unit will not kick on.
sounds like spark ignition coil bad the little fan combustion fan will run even after a fail ign attempt.
turn off power/restore power the unit will try to fire the part is easilly avail and easy to replace
Jan 18, 2010 | Ruud UBHC Air Conditioner
Home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd [email protected] cap
Sep 27, 2009 | Goodman CLQ36AR49 Air Conditioner
I have a Goodman ckl49-1 airconditiong unit that
Check for burned wires at the outside unit and if the fan doesn't work could be the capacitor or the fan motor itself , i would try replacing the capacitor first is no more than $25.
Aug 27, 2009 | Heating & Cooling
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman CK36-18: Outside fan kicks on, but
Sounds like a bad capacitor. They can be bad and the fan will still run. Turn off power and check for burnt wires on the top of the contactor going to the capacitor or on the top of the capacitor.. Check terminals on the compressor also. When capacitors go bad they are slightly swollen. They can also look good and be bad . Could be compressor but start with capacitir and wires. IWork on a lot goodman units. Most of the time it is the cap.
Jun 03, 2009 | Heating & Cooling
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
2 to goodman ac unit model a24-08
Replace the fan relay switch in the airhandler(inside unit).
May 19, 2009 | Goodman Heating & Cooling
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
347 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
jdthefixer
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
