Re: our nokia 3315 mobile is not charging ,what is the...
Check first your charger unit for cut or loose connection. If you can clean your unit's board this could help. But if the charger IC is shot you better bring it to a cellphone repair shop.
apne phone ki battery naye dalo battery dal ke phone charge karo.agar display pe charging dikha raha hai to phone ke on off switch me hi problem hai,i mean pcb se fault hai
If you forget the security code means get the master reset code for your nokia mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, so get the master reset code for your Nokia 3315 model mobile from this site Unlock-free.com, it has the best services for the master reset code for your nokia mobile.....I hope this may helpful to you.........
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
