Question about Archos Internet Media Tablet MP3 Player
ARCHOS G6S RECOVERY (CODE 101)
Hi! I have Archos5/Display show the message --- ARCHOS G6S RECOVERY (CODE 101)/Is this reparable?
Posted by vadim_budnik on
  • Fidel Juarez Apr 24, 2009
    my archos5 shows archos ggh recovery 101 what can i do?
  • Anonymous May 01, 2009
    i've got the same problem. in the recovery mode it says Archos G6S recovery (code 101). when i choose any of the menu options, it just resets itself and comes back to the same recovery menu
2 Related Answers
Anonymous
  • 5 Answers
SOURCE: recovery code 101
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Posted on Jul 24, 2009
Anonymous
  • 492 Answers
SOURCE: my archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Posted on Jan 12, 2010
Archos 101 internet tablet keeps going onto archos A101IT recovery when i turn it on i try to repair or format the devive and it just jeeps failing
every time i turn on my tablet it pop up archos A101IT Recovery.would u like to recover your system.no update firmwear.repair system.format system
Jun 26, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Bought my tablet as a window display item. archos 101 How to end demo mode ? Thanks
Power off by holding the power button for 10 seconds.
Press "Volume +" button and power it on (press power button to start while holding "volume +" until the tablet displays recovery mode. Select the "Format System" option.
Jul 06, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Archos 101 internet tablet cant get out of demo mode
Try this:
Power your Archos 101 off by holding the Power Button for 10 seconds (this fully shuts it down).
While holding the Volume + button power it back up (tap power button to start up, hold volume until the tablet enters recovery mode, you'll see a series of choices instead of the demo mode).
Choose the Format System option.
When this process is complete make sure not to select Demo Mode as Android boots and the Archos 101 gets up and running.
Feb 20, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Sir , i have one archos5 and i want install flsh player and widgets. pleas help me
boa tarde gostaria de saber se tem como me ajudar pois tenho um archos 5 e ele aparece o code 108 mais ele nao me deixa nem reparar o disco e nem formatar ele sempre quando escolho uma das funcoes ele reinicia e so fica congelado na tela de apresentacao da archos
Apr 25, 2010 | Archos 5 MP3 Player
My archos is showing recovery code 101
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Hi,my archos5 start up repeatedly, how can i do?
You might want to try hitting the reset button when it comes on. the reset button is on the bottom next to the connectors you will need a paper clip. I hate to say it but you probably have to do a hard reset. Have you downloaded the latest firmware make sure you have either a copy of your original firmware or if you don't know which is your original firmware download the latest & save it to your desktop. When the archos screen comes on hold the volume button until the white screen with repair,recovery or format comes on first try repair or recovery your last choice is to format. Usually a hard format fix's most problems. I hope I have been helpful.
Aug 18, 2009 | Archos 5 MP3 Player
Archos5 register
How did you get your archos, if you can't register call this number for archos tech support.
Our toll-free number is: 1-877 300 8879
Hours : daily 7:00am - 11:00 pm CST, 7 days a week
Jul 12, 2009 | Archos 5 MP3 Player
After formatting the archos5 ,the device doesnt get recognised
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up, just pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
?videos and movies to my archos5
without the video podcast plugin you can only use wmv and avi formats if you have the plugin then mp4 quicktime and ipod video should work.. Following lisks are for free Archos games and movies. Movies actualy for psp but as i said if you have plugin they shoul work or you can convert them to avi or wmv
link for archos games Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://brys-psp-help.webs.com/archosmoviesandgames.htm
link for archos movies Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://brys-psp-help.webs.com/pspgamemovies.htm
Feb 02, 2009 | Archos Internet Media Tablet MP3 Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
2,098 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
