Question about NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Cd rom not detecting cd
My laptop is fujitsu 2000 model
i upgraded it with windows xp
my system is not detecting the cd
it is saying that please insert a disk into the drive
Please help me in solving this problem
Posted by mailrama29 on
Anonymous
  • 700 Answers
Try to uninstall then reinstall cd driver. Or update its driver.
Posted on Apr 11, 2009
I have a Fujitsu siemens scenic desktop, I want to change win xp, but when the time to leave after cd-rom and it says press any key, it boots from the CD, you can stop trying to do?I have a Fujitsu siemens...
if you want to change the operating system then put the CD / DVD of Windows 7 or Vista Bootable Disk and change the Bios settings like First Boot Device and Second Boot Device. Before all these things try to take the Data backup
tip
Error code 7
To resolve this issue:
  1. If you are upgrading Windows 98 or Windows Millennium Edition, follow the troubleshooting steps that are described in the following Microsoft Knowledge Base article: 310064 (http://support.microsoft.com/kb/310064/ ) HOW TO: Troubleshoot Windows XP Problems During Installation When You Upgrade from Windows 98 or Windows Me Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  2. Perform a clean installation of Windows XP:
    1. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive.
    2. If Windows automatically detects the CD-ROM, click Install Windows to start the Windows XP Setup Wizard. If Windows does not automatically detect the CD-ROM, click Start, click Run, type CD-ROM drive letter:\setup.exe, and then click OK.
    3. Press ENTER.
    4. Click New Installation, and then click Next.
    5. Follow the instructions on your screen.
  3. When you receive the "Press F6 to load SCSI/Raid Drivers" prompt, press F7 to bypass Advanced Configuration and PowerInterface (ACPI) detection.
  4. Finish the installation of Windows XP.
on Mar 16, 2010 • Computers & Internet
2answers
How do I upgrade my windows 7 to XP or atleast 2000? Pls help
you mean how do you downgrade your windows 7 to xp, you will need a copy of xp and boot from the cd and follow the instructions to install XP
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
I have a problem in my Toshiba pro L300 laptop. I have upgrade the operating system from Windows vista to windows 7. After that the CD-ROM does not detect any CDs and DVDs. I have seen the CD-ROM driver in...
Hi, this is a common problem, I have put a link below to do a free driver scan, hopefully it will detect the drivers you require.
http://www.opendrivers.com/modeldriver/Toshiba_notebook_Satellite%20M50-driver-download.html
Can not install windows xp in my system send error code 7
try this one:
    3. Press ENTER.
2answers
Was given inspiron 5000e laptop- / can it be
Yes, you can upgrade to windows XP but it will require upgrading the memory to the maximum supported memory of 512 MB. It is set up with PC100. I would suggest going with PC133 when you upgrade the memory. Be advised though that the PC100/PC133 memory is expensive new but you can usually shop around and find it used for a cheaper price. The 800MHz processor will support the XP operating system.
No operating system found after win xp uprade -
your operating is currupt ,you need to be repair your window.you choose the first boot device cd rom & repaire it.
1helpful
2answers
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Fujitsu U810 problem ( not booting )
that means that you need to repair it in order to get the laptop back to its normal condition insert windows xp disc and repair the system that's what i think
NEC CD-2800D (cd2800d) 24x CD-ROM Drive Logo
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Mehandi Husain ...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
