Question about iLive ITP582B Soundbar iPhone Dock
HOW DO I HOOK UP THE ITP582B TO MY TV - iLive ITP582B Soundbar iPhone Dock
Nikos Petrakis
You can connect to auxiliar audio output check your tv is a red and white connection
Posted on Oct 29, 2021
1helpful
Want to use TV as monitor for laptop
There is no way to hook the TV to the laptop. You can hook the laptop to the TV but not the other way around. It is done with a VGA monitor cord. The same one that you connect to your regular monitor. Your TV will have a plug labeled VGA.
Could I hook up Apple TV with this tv?
Read the Apple Tv box owner manual can it be hook up wih RCA component R,Y,W cables,than yes.This tv is an analog tv only can be functions buy component cables not anything else will able to hook up with analog tv to get a video picture.
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Can I hook up my ps2 to my tv?
depends on the outlets you have on your TV. but unles its a very old tv its a sure bet you can hook up a PS2
How do i connect my dvd player up to my tv and direct tv?
Hook your coax cable output from sat. to input on tv, then hook your rca cables from dvd output to input on sat. There are several way to hook one up depends on witch hook ups you have , If this don't work or you don't have theese hookups or wann use different hook ups email me at [email protected]
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
Cable hook up on tv is broke. trying to hook cable up to jvc dvd
Some times you can try tapeing it on (Black tape). Thats what i had to do one time.... It worked.
3helpful
Hook up for pioneer htv c1
To hook up to tv you have to make sure your tv has a (audio out) port then use rca cables and hook up to (audio In) port in the back.
2answers
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
How to hook up my vcr to my admiral tv.
look to see if there is a place to put a cable cord if there is you need to hook a cable cord from the tv to the vcr and from the vcr to the tv. so you need to small cords.
iLive ITP582B Soundbar iPhone Dock Logo
Top iLive Audio Players & Recorders Experts
ruggeg
 Grubhead
Grubhead
ray gallant
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
