When using the volume pod to raise and lower volume it is causing the speakers to crackle loudly
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
SOURCE: Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
SOURCE: Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
