Question about Sylvania Computers & Internet
Ssl2006 sylvania flat screen right side of screen is white any ideas on what it is and how to fix it ???? looked inside small discoloration on right side of main circuit board but nothing looked or smelled burnt !! can some one shed some lite on the white of my screen please
Posted by rayray on
mike stubbs
    New Friend:
    Problem Solver:
  • 5 Answers
The could be caused by a fault with the LCD screen or with the VGA ribbon that runs to the screen.
Posted on Aug 26, 2013
3 Related Answers
ssebata paul
Paul Ssebata
  • 159 Answers
SOURCE: line across screen
scane for virus and reinstall the operating system
Posted on May 30, 2009
Anonymous
  • 53 Answers
SOURCE: spreading brown stain on screen
your LCD panel is damaged, if it is only a year old it should be under warranty, it needs to be repalced.
Posted on Jun 11, 2009
k24674
  • 8092 Answers
SOURCE: burnt out power board
I sympathize with your problem, but I think you are knocking at the wrong door. You should contact your local Packard Bell dealer.
Hope it helps
Posted on Aug 28, 2009
Sylvania ssl2006
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 20, 2017 | Televison & Video
Sylvania ssl2006
How do you know it is the fuse? Did you take it apart and look at the power board? If so, what is the model number?
Aug 12, 2013 | Televison & Video
Half screen on sylvania tv is black (or white)
There are some defects in the board inside and should only be handled by a qualified service technician.
Aug 16, 2012 | Sylvania LC320SL8 Television
Colors are very off, epecially whites.
if contrast etc not set incorrectly it may be a issue on the main board which processes all signal inside the set===a 37 inch might cost you more to fix than to replace.
Mar 14, 2012 | Dynex DX-LCD37 TV
My Sylvania 32" just had the entire screen go
My Sylvania 32" just had the entire screen go white. There was still sound but the picture was gone and just the white screen. Any ideas?
Oct 11, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Sylvania SSL2006 dead, won't turn on. fuse is ok,
Hi larry
Since you know electronics that will make the explanation simpler;
On your tv model there is a very common problem that you may want to look at;
There is a small board on the right hand side(backlight inverter board),
Look for a shorted D309 , it is a 9.1volts 1watt zener diode.
As i said it is a common problem for your model.
But there is also the power supply;
All lcd tv`s nowadays it seems end up with bad capacitors in the power supply,
You can recognize them by their rounded tops and you`ll find them at the output of the power supply along the 5/12 and 24volts line.
But especially on the 5 volts line.
If your not sure which ones then replace them all (there might be 6 or 7 of them) it won`t hurt and eventually they will go anyway.
Hope this help good luck
Jan 08, 2010 | Sylvania Televison & Video
Dead t v
Good Luck! My SSL2006 tv would cuts off when turned on. Under warranty, the local auth. repair shop tried unsuccessfully to replace parts to fix it. In addition, the repair shop told me it was difficult getting thru to parts support. Either the wrong parts were sent, the right part didn?t work, or additional authorization was required to repair TV. On many occasions I made calls to Sylvania, on the repair shops urging, to find out the status on its repair parts to help get the right parts sent. The set was in an auth repair shop from Feb.-Aug. The shop couldn't fix it. It was sent to Sylvania's repair center in CA, August 18th. WHEN WILL I GET MY TV BACK? I want a new TV!! I have been without this TV for over 6 mos.! I'm very upset with customer service and its repair centers and will never buy nor will I recommend purchasing a Sylvania product.
Sep 02, 2007 | Televison & Video
Black screen after 1-2 minutes.
Hi, I just fixed one I bought on eBay with the same problem. My problem was caused by the screen backlight inverter. Fortunately I had one from another TV I bought last year on eBay. The repair only took about 15 minutes. Your best bet is to contact Funai Corp. and really complain even if it is out of warranty. They make Emerson, Funai, Symphonic and Sylvania and all the parts inside are the same (from the same years). If that don't work look on eBay for one with a broken screen or some other damage, call your local dealer and see if they have the inverter from a broken TV or ask around. We have a freecycle group in Michigan that recycles things rather than throw them in landfills you may have one in your state too !
Good Luck,
Jul 15, 2007 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Computers & Internet Logo
Top Sylvania Computers & Internet Experts
Mike
Joe Goldman
Joe Goldman
Paul Bade
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
