Question about Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio
I have two Oregon Scientific systems. they are interfering.
I have a model BAR888RA with three remote temp. only sensors. I also have an RMR 136HG with three temp + humidity sensors. The BAR888RA is picking up channels 1 and 3 from the RMR 136HG. how can i make the systems independant? they were before, it only began acting up when i changed the batteries in the BAR888RA.
Posted by twohey on
Anonymous
    Problem Solver:
  • 8 Answers
Two things...
1) press reset on the base unit
2) press and hold for 2-3 seconds the channel button
You should be in business
Posted on Jul 11, 2009
MODEL WMR80 / WMR80A
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use a stick, needle, what ever you can (but you need two) and hold down the reset button on both the sensor and the clock at the same time.)
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Oct 09, 2013 | Oregon Scientific Lwb0997110113004...
Oregon Scientific RAR501A 4 Zone Temp and humidity sensor not working
Check the batteries and then you can reset the device to detect all the sensors. If that does not work, contact the manufacturer for a replacement.
Aug 14, 2013 | Oregon Scientific Measuring Tools &...
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
Remote sensor (thn122) not working, batteries changed, terminals cleaned
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
Oregon scientific IWA 80055 Outside temp won't display and I have replaced the batteries on the sending unit and it blinks two times every few seconds.
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
Jan 31, 2010 | Oregon Scientific Lwb0997110113004...
I cannot open the remote sensor for my Oregon Scientific PSM06AR.
I believe the back of the sensor slides open. There may be a faint arrow on the back that indicates the direction in which you push.
My unit took well over 24 hrs to reset. I think it has to do with the position of the satellite in relation to where you live.
Jun 29, 2009 | Oregon Scientific Lwb0997110113004...
Oregon Scientific Radio controlled Thermo Clock RMR382A -
Check the channel mode that you are in. I play with the channel /memory buttons on mine and I finally get it to work. Sometimes it worksfor weeks sometimes just a day. Just glad I can get it to work - thought it was the remote unit but I was wrong.
Sep 03, 2017 | Oregon Scientific RMR-182A Clock Radio
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio Logo
293 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
STEVE SPAM REMOVER
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
