HP LaserJet 4 plus Printer Logo
Question about HP LaserJet 4 plus Printer
80 service(0006) - HP LaserJet 4 plus Printer
I have a error code E000002-0006 on my Canon IMAGE RUNNER ADVANCE C2020. How do I fix the problem?
You need to clear that error from service mode first if problem persist replace the fixing unit
What does error code E000002-0006 mean?
if you machin is canon e002 mean power problem
E000002
https://www.youtube.com/watch?v=OFtNaC1vv88
-and service the fixing unit element
E00006
Chek the fixing unit Fuser Film
1helpful
2answers
Enter test mode
Hi
Problem with the temperature sensor.
Try disconnecting/unplugging from power and connecting after a while.
Code for sharp tv
Hello
Three ditgit universal remote codes for Sharp TV with GE remote are:
591, 604, 729, 671, 679, 684, 809
Four digit codes are:
0079 0123 0063 0020 0004
.............0009 0226 0266 0006 0095 0122
2helpful
Konica 7145 i have an error message 0006 I have replaced drum in drum assy. it gave me an f26-3 error message performed L detection now it gives 0006?
Check Toner control sensor board, on drum unit behind drum, is clean, try L-detect then, try it a couple of times. If that fails you will then have to change developer, and perform L-detect.
Matrix 3000 "bottom fan fail" need a replacement fan. APC said they don't have in stock and is discontinued.
The APC Matrix-UPS 3000 Isolation Unit IU bottom fan APC part number appears to be 490-0006-A. There are three OEM parts that APC appears to have used:
NMB Technologies 4715KL-05W-B30-P00
Japan Servo CNDC24B7-34
Sunon KDE2412PMB1-6A
But any fan that has the following specs should work:
119mm x 119mm x 38mm, plastic (black) 94V-0, ball bearing, 2-wire, 24 VDC (9.0V min, 10V to 27.6V), 2800 RPM, 80 CFM min, 41 dbA max
Ben Johnson
Marvin
Marvin
