Question about Clothing
How do I remove sweat and antipersperant from shirts? New machine this winter,Kenmore High Efficiency, low water machine, didn't have trouble then. Have tried changing to regular ,not cold wter Tide using soaking, prewash and the stain boost and second rise cycle
Posted by Nancy Macek on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: soak/prewash led flashing after about 10 seconds...
It is a pressure sensor fault, call in an expert to fix, these machines are far too complex for anyone else to repair Good luck
Posted on Sep 14, 2007
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Posted on Feb 13, 2009
Anonymous
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
Anonymous
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore 500 top load washer starts to fill withwater then stops
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
If the lid switch is found to be defective, it can be purchased at any of the following websites:
searspartsdirect.com
applaincepartspros.com
pcappliancerepair.com
repairclinic.com
The average price is $25 to $35. Prices vary between these sites, so shop around for the best deal.
This is a very simple repair, but if you still have questions, please let me know. I hope this helps you.
Posted on Oct 06, 2009
Why Kenmore low water wash machine dont wet parts of sheets?
Or your water level switch need replacing based on your information.
Oct 06, 2014 | Sears Kenmore Elite 4.5 cu. ft....
We have a Kenmore top-loading high efficiency low-water washer that we purchased last year. It had been working perfectly until the other day. When I try to start a load, water is going into the the...
Have any modifications been made to drain? If drain hose is too low or too far down in pipe or installed airtight, it can act as a siphon draining as fast as it fills.
Aug 31, 2017 | Kenmore Washing Machines
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Put fabric softener in the soap dispenser
Just run the load. You can always re-wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Kenmore Washing Machines
Dehumidifier efficiency
I'm surprised that you are trying to dehumidify if you are in the northern hemisphere right now.
But, before you go off trying to fix the refrigerant, see if you can get a glass of ice water to sweat near the dehumidifier. While relative humidity might be high in cold climates right now, it's a relative number, as the total grains of moisture is far lower than what it would be in a warmer climate. Cold air saturates easier, because it holds less, moisture.
Most people use a humidifier in the winter because they want to saturate the air with water, which is better for the human body, and minimizes static electricity.
I can help you diagnose the dehumidifier if you want. The coil should only get to 40 degrees or so. But the sweating glass of water will tell you if there is enough moisture in the air for the dehumidifier to wring out.
Jan 30, 2009 | Haier HDN655E Dehumidifier
Clothing Logo
220 people viewed this question
Top Clothing Experts
Anon
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Clothing Expert? Answer questions, earn points and help others
