SOURCE: no power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
SOURCE: no sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
SOURCE: Receiver very low when watching tv or dvd
It's just "Digital Audio" vs "Analog Audio" You can use the "Volume Offset" function in the receivers "Main Menu" to compensate for this. Go into the menu then go to audio and or input settings and you can adjust the offset and lock it in. If you still have a problem, post a comment and I can help you some more. There is not a "problem" it's just the way the audio is transmitted. Like when your watching TV and a commercial comes on and BLOWS you out of the room. That's going from clean digital to noisy analog.
