Question about Pioneer SX-205 Receiver
PIONEER SX20 AMP STUCK IN STANDBY - Pioneer SX-205 Receiver
According to manual there is pre/amp on Pioneer sx 20 what connections do I use to connect graphic equaliser
Yes, the SX20 includes a preamp including a phono stage. (nice!) There is already equalization in the SX20 available via the bass/treble controls. To hoop up an external graphic equalizer, you should be able to connect it to the 'Recorder' IN/OUT and then select the tape monitor input to hear the equalized signal.
http://www.hifimarket.cz/files/img/zbozi/pioneer/_640x480/sx-20-4.jpg
My Pioneer PDP508XDA tv is stuck in standby mode since a power outage
try unplugging and then hold the ower button in untill all lights go out. plug back in and try to power on.
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
2answers
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
2helpful
2answers
Amp err
Same problem here VSX-916 AMP ERR
1helpful
Tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
27helpful
2answers
Standby/ON keps blinking...Pioneer VSX-D812
JUST PRESS ADVANCED SURROUND & ENTER FOR LIKE 3 SECONDS.. THAT WILL RESET THE SYSTEM CHIP INSIDE.. :)
Pioneer Receiver will not come on
press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
Pioneer SX-205 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
