Health & Beauty Logo
A
Anonymous Posted on Aug 26, 2013
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB inserted). please help.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 27, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
426
Points
0
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
  • fredwens
    fredwens Feb 21, 2014
    this is not working for me. When I insert the usb stick, it starts blinking as if it was transfering data, but I never get the END message. It just stops, then if I insert the stick in the computer it tells me there's no data. I'm following every step as mentioned: selection of the user (same one as the one I use in the app), SET with the usb key in the scale, but nothing...
Salter
I have been able to locate a manual for Salter Mibody scales. Not sure if this is what you are after.
http://www.mibody.co.uk/EN/9119/downloads/Instructions.pdf
tip
Guide: Windows XP Lost Password Recovery
So you <b>lost your Windows XP user password</b>? You can try your best to remember XP account password, such as:<br /> <ul> <li>* your name?</li> <li>* a loved one's birthday?</li> <li>* something from your childhood?</li> <li>* a pet's name?</li> <li>* your home or office address?</li> <li>* the name of a friend or family member?</li> <li>* a frequently dialed telephone number?</li> <li>* a favorite food?</li> <li>* a combination of any of the above?</li></ul> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/forgot-windows-xp-password.jpg"><img src="forgot-windows-xp-password-500x187.jpg" /></a><br /><br /> Still Can't Find Your Windows XP Password? If you've given it your best shot but that all-important Windows XP password is still hiding somewhere in your mind, then it's time to try something a bit more technical.<br /> Don't worry - There is a easy way to recover the password. Windows password recovery tool is a software program designed to recover or reset/delete your Windows XP password. It can sometimes be difficult to use but if there's no hope of remembering the password and you can follow some simple directions, Windows password recovery tool is life saver.<br /> <b>Notes:</b> You need a <b>Windows XP Password Reset disk</b>. If you don&iexcl;&macr;t have created it before, you should use the Windows Password Recovery Tool to burn a reset CD/DVD or USB flash drive.<br /> Step 1. Download the Windows Password Recovery Tool Go to the <a href="http://www.windowspasswordsrecovery.com/index.htm">official site</a> of Windows Password Recovery Tool, and <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">download it for free</a>. Install it with default options.<br /> Step 2. Create a Windows XP Password Reset disk Run this soft, insert a blank cd/dvd or usb flash drive. Follow the step-by-step guide to burn a <b>Windows XP Password Reset disk</b>. You can burn it to a cd/dvd or USB, it depends on your personal condition. After burning successfully, you get a password reset disk. Now insert this password reset disk into the locked computer which you <b>lost Windows XP Password</b>.<br /> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/burn-windows7-password-reset-disk.jpg"><img src="burn-windows7-password-reset-disk.jpg" /></a><br /><br /> Step 3. Set the bios config to boot from cd/dvd or usb <ul> <li><b>1.</b> Start your locked Windows XP Computer, press <b>Del</b> or <b>F2</b> button while the computer is initalizing. The initial startup screen may be similar as this image. If you do that, you may see the bios config screen.</li> <li><b>2.</b> Go to the boot menu and change bios setting to make it boot from cd/dvd or usb firstly.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/boot-computer-from-cd-first.png"><img src="boot-computer-from-cd-first.png" /></a><br /></li> <li><b>3.</b> Press F10 to save your changes, then restart this computer.<a href="http://www.windows7password.net/wp-content/uploads/2011/01/save-bios-change.png"><img src="save-bios-change.png" /></a><br /></li> <li><b>4 .</b> After restart, the computer will automatically load Windows password Recovery Tool and you can start to <b>reset Windows XP Password</b>.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/loading-password-reset-disk.png"><img src="loading-password-reset-disk.png" /></a><br /></li></ul> Step 4. Recover Windows XP Password with the password reset disk. <ul> <li><b>1. </b>Choose the Windows XP Installation if you have more than one OS in this computer.</li> <li><b>2.</b> All Windows XP users will be listed. Select the user name which you forgot its password, click reset button.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/recover-forgotten-windows-xp-password.png"><img src="recover-forgotten-windows-xp-password-500x375.png" /></a><br /></li> <li><b>3.</b> A dialog box will be pop-up, click Yes to confirm reset, then this <b>Windows XP user password</b> will be reset to blank.<br /><img src="confirm-reset-xp-administrator-password.png" /><br /><img src="reset-windows-xp-password-successful.jpg" /><br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/after-resetting-xp-password.png"><img src="after-resetting-xp-password-500x307.png" /></a><br /></li> <li><b>4.</b> Eject the password reset disk, and restart you computer, <b>login Windows XP</b> with a blank password.<br /><a href="http://www.windows7password.net/wp-content/uploads/2011/01/loading-windows-xp.png"><img src="loading-windows-xp-500x302.png" /></a><br /></li></ul> <a href="http://www.windows7password.net/wp-content/uploads/2011/01/login-windows-xp-without-password.jpg"><img src="login-windows-xp-without-password-500x377.jpg" /></a><br /><br /> <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Trial.exe">Windows XP Password Recovery Tool [Download]</a><br />
3helpful
12answers
Forgot password windows 7
Want to recover Windows 7 password? Do you have tried your admin password or safe mode? Do you have a reset disk? If all failed, please try Anmosoft Windows Password Reset, which I used before and think it is the best reset software.
4answers
Need to crack my windows vista password
Four steps can help you reset the lost Windows 8/7/vista/xp/2008/2003/2000 password:
Step 1: Download Windows Password Rescuer/Windows password recovery tool on any available computer you have access to.
Step 2: Install Windows Password Rescuer and run it to burn a bootable CD/DVD or USB flash drive
Step 3: BIOS setting of your locked computer to set it boot from CD/USB.
Step 4: Insert the newly CD/USB to the computer.Reset Windows password successfully after Windows Password Rescuer starts.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows when you can not find target user. With this New user account you can logon your locked computer directly.
More details about the usage:
http://www.daossoft.com/documents/how-to-reset-window-2000-xp-vista-win7-password.html
2helpful
4answers
I have forgotten what my adminstrator domain password is. Is there a way to redo it or retrieve it?
The best and easiest way to reset the local or domain admin password. Reset domain password with Windows Password Rescuer Advanced. By this small software you can easily reset the domain password without lose anything and do not require any tech operation.
Get to the point, now let us see the step-by-step guide to recover domain password with Windows Password Rescuer Advanced. To recover Windows Server 2000/2003/2008 domain administrator/user password, follow four steps below:
Step 1. Download and install Windows Password Rescuer Advanced and use it to burn a Windows password recovery disk with CD/USB..
Step 2. Set the locked computer to boot from CD/DVD-ROM or USB drive.
Step 3. Boot the locked computer from Windows password recovery disk.
Step 4. Reset Windows 2008/2003/2000 local or domain administrator password by a few clicks.
3helpful
8answers
My daughter forgot her password
forgot password? You daughter forgot what password?
forgot Windows logon Password?
11helpful
11answers
Forgot windows password
Windows Password Recovery is right what you need in your case. The program is designed to reset Windows login password once you accidentally forgot it or have no access to your system. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds.
Simply rely on another computer and burn a CD, then insert it back to your locked computer. Boot the computer from the burned CD (in BIOS mode) and clear the password. It's quite easy. Best regards.
5answers
How to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
1helpful
2answers
Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
7answers
My laptop says it's locked? When I try to login my password to my laptop it says my laptop is locked?
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
